2014 450 hp
7 replies to this topic
  • Ron Hamp
Posted June 25, 2014 - 09:11 AM
I just finished dynoing a yz 450 with a head that I ported  stock cams a piston I ported And set compression @ 13.7-1  we used renegade SX4+ fuel and an fmf pipe  and also stayed with the stock remaped ecu instead of the vortex  the bike makes 3 pounds more torque than stock and nearly 7 more hp  theres more power evey where and it makes 1 hp more than a factory kx 450 that had all of the parts from an RV bike including the factory racing ecu Yamaha built a real race bike this year.
  • suzuki son of a bitch
Posted June 25, 2014 - 11:17 AM
Thats awesome.
Posted June 25, 2014 - 01:20 PM
I knew I saw the new head layout that there was a huge potential there.  Great design.   And, of course, you'd be the one to get the most from it.  Gonna be fun watching your stuff on the flat tracks.
  • SAthump
Posted June 25, 2014 - 03:11 PM
Can the 14' head be fitted to the 10-13 engines; & would that same potential exist?
Just curious
Posted June 25, 2014 - 03:34 PM
The gaskets are the same on both models, bore and stroke are the same, but the cylinder is different.  Ron would know better.  It seems to me that the '10-'13 models use the same basic head, and that you should be able to get that kind of performance with the one they came with, unless there's a big difference in the ports that I don't see.
  • Ron Hamp
Posted June 26, 2014 - 04:54 AM
the head that came on the 2013 can be ported the bigger valves from the 2014 can be fitted as well as the cams I believe the 2014 cams are shorter duration the intake only has 242 *duration if I remember correctly the 2010 was over 250* and I was using a shorter duration cam in them.
  • yzUSMCf
Posted June 26, 2014 - 09:04 PM
Wow so you have 65hp out of her???
Posted June 26, 2014 - 10:20 PM
Time to take a run with the 5 hundo's
  • Hot  47 replies
  • 0 replies
  • Hot  30 replies
  • Hot  113 replies
  • Hot  36 replies
