what are the specs on the 2006 yz450f cams? like lift lobe center
1 reply to this topic
  • Blackyz450
Posted June 24, 2014 - 11:18 AM
where can I find the specs on 2006 yz450f cams lift lobe center duration etc
Posted June 24, 2014 - 01:18 PM
You find it by searching for it:
http://www.thumperta...-2#entry9792034
Bear in mind that when you fiddle with re-timing the exhaust cam, some compensation must be made to the auto decompression pin.  The combination of cam timing and pin length controls the timing of the lifted exhaust valve being reseated at cranking speeds.  Retarding the exhaust cam requires a shorter pin.  Stock, the '06 seats the exhaust valve at about 26 degrees BTDC.
