yz450f carb boring or 13.5.1 je piston?
2 replies to this topic
  • Blackyz450
Posted June 23, 2014 - 05:46 PM
2006 yz450f would you bore the carb or put in a 13.5.1 piston.. right not it has ported head and 12.8 je piston and stage 1 hot cams and it is drag raced and I run 110 fuel because we have to at the track
  • YZX
Posted June 23, 2014 - 06:08 PM
A higher compression piston usually gives you more bottom end power. It can also make you lose top end too.
Posted June 24, 2014 - 06:13 AM
Bore the carb.  Alternatively, you can fit the carb from a CRF450R.  They're 41mm vs. 39 on the YZ.
  • 5 replies
  • Hot  50 replies
  • Hot  36 replies
