Carb, bad gas, or a mix of both?
5 replies to this topic
  • tehehodi
Posted June 22, 2014 - 02:23 PM
Bike:
2000 Yamaha yz426f
Stock exhaust, stock air filter.
I took it on its maiden voyage Saturday after plating and I know it kinda sputters at cruise/part throttle sometimes. Didn't think much of it but when I was on my way home from this short ride, it came to a sputtering/backfiring stop like it ran out of gas. I was riding up an incline and it had plenty of fuel in it. I tried numerous times to try and kick start it again after the incident and it would randomly start for like 5 seconds then backfire and then die and not start again. Towed it home and now it starts up just fine on the stand. Maybe I'm to short but I leaned it up against a crosswalk light and it still wouldn't start. (I don't normally have to do this but I thought that maybe I wasn't kicking hard enough)
Maybe a carb cleaning and new gas? This gas has been in it since winter. It idles fine, but I know when I try to go from a little bit of throttle to WOT or close to it would hesitate then kind of sputter then kick in like vtec or something.
What do you guys think?
  • walent215
Posted June 22, 2014 - 07:11 PM
Bike:
2000 Yamaha yz426f
could try cleaning the carb and installing new fuel but it sounds kind of like a bad coil if it only does it after it warms up then starts up fine after cooling down.
  • tehehodi
Posted June 22, 2014 - 07:35 PM
Makes sense. Is there a way to test the coil via the manual?
  • tehehodi
Posted June 22, 2014 - 08:38 PM
Found the tests in the manual. I'll check that and report back.
  • tehehodi
Posted June 23, 2014 - 02:19 PM
Thanks for the tip!
Just tested my coil. Resistance should be .20 - .30; it's reading .14
Tested the secondary coil, got no resistance at all.
I think I found the culprit.
Checking the CDI now.
  • walent215
Posted June 24, 2014 - 07:55 PM
10-4, no problem.....I know the dealer tested mine and got some weird numbers that made it seem ok but was off a tad...glad you found the problem
  • On January 15, 2017
  • Hot  50 replies
  • Hot  38 replies
