2010 FREE PISTON BROKE?
9 replies to this topic
  • walent215
Posted June 21, 2014 - 12:52 PM
next to the oring on the free piston is what looks to be a Teflon or nylon washer with a "crack" in it...kind of like a lock washer...not sure if that is the design or it is broke? also the piston has 2 holes drilled in it...is this stock or has someone drilled it? thanks in advance.
Edited by walent215, June 21, 2014 - 12:56 PM.
  • slammedmind
Posted June 21, 2014 - 01:44 PM
Im not sure on the piston, but the nylon washer is fine, thats how it comes.
  • walent215
Posted June 21, 2014 - 01:47 PM
awesome...thanks a lot....
  • sploon
Posted June 21, 2014 - 04:00 PM
Really common for them to crack. Altho i dont think thats a crack its like a guide to locate the oring.
Look at upgrading to a alloy piston. i went through 2 plastic pistons before i had a plastic one smash and cost me 1 fork cartridge >.< $$$
2011 yz250.
I dont know where in the states you can buy them because Norm Cobb from suspension tech in New Zealand had them made.
  • Monk
Posted June 21, 2014 - 04:06 PM
Someone drilled the piston....
DaveJ with Smart Performance will sell you aluminum pistons for about $70 a piece...
  • walent215
Posted June 21, 2014 - 04:58 PM
so these pistons break often and destroy cartridges? really? wow.....so if we don't upgrade to aluminum we run the risk of catastrophic failure...not good...
Posted June 21, 2014 - 07:09 PM
Who said anything gets destroyed?  All the OEM parts of that piston are plastic.  The most most catastrophic thing that's apt to happen is you'll get a bit of it stuck in something like the bleed port and have to do more than the normal amount of disassembly.
Once they're drilled, they aren't likely to fail in any case.
The "washer" is a high pressure seal.  The "crack" is the "scarf-cut" on the ends that eliminates end gap while allowing the seal to expand.  Oil gets behind these and blows them out against the bore walls, forming a better seal at high pressure than the O-ring can.
  • walent215
Posted June 21, 2014 - 07:35 PM
sploon...a few posts up from yours....
thanks for the info on the piston and "washer" ....good to know....I feel much better knowing that....
Edited by walent215, June 21, 2014 - 07:41 PM.
  • sploon
Posted June 21, 2014 - 08:07 PM
..... i said you should look at replacing it...... esp since its allready apart. it doesnt happen to everyone but i just had a bad run with them and the only explanation i could get out of it was it was caused by lack of finess overjumping etc. Dont jump to conclusions but the alloy piston is what i put in all my bikes from now on.
  • walent215
Posted June 22, 2014 - 04:45 AM
Not jumping to conclusions, just wondering what the story is with them? Thanks everyone for the education....feeling much better about them now....I put new seals and bushings and new fluid in ....can't wait to try them out....
