03 WR vs '12 WR450...
25 replies to this topic
  • Navaho6
Posted June 20, 2014 - 05:47 PM
#21
Get the competition kit (programmable ecu and throttle stop screw) sold together for $100.  drill out the oem muffler restrictor (pea shooter), and get the mapping reset (by dealer) to FMF map.  You can fit a bigger muffler tip on the oem muffler (same one that fits older WR's), and you'll be set.  I can rent my FI tool to you for resetting the CO level to make it run even cooler.  PM me when the deal is done.
  • GP1K
Posted June 21, 2014 - 06:33 AM
#22
Really enjoying all the discussion regarding this subject guys... Based on what I'm reading and the fact that I'm not interested in putting a top end or any more money into my 03 at this time- I am definitely going to grab a '12 from my local dealer this next week. I'm doing some research with the search function now- but if anyone can recommend what mods (engine/exhaust wise) that need to be done to open it up like my 03 is. Don't want to touch internals (cams) but remember reading bout a GYTR ecu, throttle stop and taking some plug out of the stock exhaust... What if anything else do I need to get from the yami dealer before I leave? Hoping to work some of it into the deal... Appreciate everyone's thoughts!
You should get your dealer to set the CO level, which requires a different 'tool' than the GYTR tuner. If they can't or won't there is one for rent for forum members.
  • Toothmech
Posted June 22, 2014 - 05:06 PM
#23
Sorry- new to the fuel injection stuff... What is the CO level? If this something most dealers should be familiar with? Or am I going to have to walk them thru it to get it right?
  • GP1K
Posted June 23, 2014 - 08:03 AM
#24
Depends on the dealer. Now that the bike has been out a couple of years, some dealers have been through it and know the drill. I had to explain it to my dealer the first time, they thought I wanted a different FI map with the GYTR tool.
Posted June 23, 2014 - 01:10 PM
#25
CO level is simply the idle carbon monoxide readings.  It indicates the relative rich/lean state of the engine's idle base line.  Most of them are a bit lean for emissions reasons.  The GYT-R tuner is not capable of resetting this parameter.
  • Toothmech
Posted June 27, 2014 - 07:11 PM
#26
Pulled the trigger today on the '12. Got it for $6,400 otd. Came with a brand new set of bark busters installed and got the comp kit and exhaust tip thrown in on the deal. Just played around w it today behind the house- don't really want to ride it until I get it opened up... It's a dog compared to my tuned 03... Should have the ecu by next week. From there can I ride it safely before putting the FMF tune on it? The dealer "isn't sure" they have the right tuner to adjust the map. Don't really want to spend $280 for a tuner I'm going to use once... Ideas? Also- what's the consensus on setting the CO level? Doing a lot of reading and seems like many people don't get much out of it. Looking forward to getting her dialed in!!
