wont start. think its a bad coil.
8 replies to this topic
  • psmith994
Posted June 15, 2014 - 08:29 AM
2001 wr 426. ran fine a couple of months ago. been piecing this thing together for almost a year now. now no spark. none. I think its the coil (do these things go bad?) so ive been looking for one. found a coil for a yz426. will that work or do I have to do a bunch of stuff to it?
  • mebgardner
Posted June 15, 2014 - 09:56 AM
Do you have the battery on trickle charge? Why is the the coil, and not the battery, suspect? (I'm not too familiar w/ the older cycles. Lemme guess: Kick start only, no battery huh...).
Anyway, check the grounding terminals. They could have developed corrosion over the storage time.
  • psmith994
Posted June 15, 2014 - 10:13 AM
Yeah.... no battery. Checked grounds already. Gunna check again just to be sure.
  • mebgardner
Posted June 15, 2014 - 10:25 AM
Electrical parts don't usually "go bad" just sitting around. Something else has changed.
Check your switch gear with an ohm-meter. toggle the switches and look for a change in meter reading (0 ohms = short, infinity = open) as you toggle the switches.
Check the connectors, push 'n pull them (carefully, they're old!). Alternatively, disconnect them and eyeball the interior of the connector, looking for dirt / rust / pitting, and take a metal file to the contacts.
  • psmith994
Posted June 15, 2014 - 03:21 PM
Ok. I'll let you know
  • psmith994
Posted June 20, 2014 - 11:30 AM
so....I took the stator cover off and found oil on that side. is there supposed to be oil there or is something very very wrong? time to go research :/
  • flyandride
Posted June 20, 2014 - 08:37 PM
There will be oil in there, that's normal.
  • stevethe
Posted June 21, 2014 - 06:03 AM
You might have to check at night sometimes it's hard to see. If your pilot jet is plugged from sitting it wont start.
  • psmith994
Posted June 21, 2014 - 08:27 AM
Nope no spark. Grabbed the coil wire. Nothing. However, the I checked all the ohm readings and everything on the stator, coil and tps checks out fine. Which leads me to the cdi. (insert sad face) is there a way to test these things before I drop 400 bucks on a new one? And is this a common problem?
