Brakes
10 replies to this topic
  • ManilaMike
Posted June 13, 2014 - 08:34 PM
Optimal choice for Reno area.
  • RMK800
Posted June 15, 2014 - 09:55 AM
One thing you can do for stock brakes is go with a sintered break pad. I noticed a very good improvement in stopping power over OEM. The next thing would replace the rotor. You can get sintered brake pads at rockymtnatv for 10.00 and their great, 4 1/2 starts for the reviews.
  • Krannie McKranface
Posted June 15, 2014 - 01:15 PM
Sintered pads are only good for short stops, and they heat up the fastest, so feel is not as good as stock.
If you do any long down hills the sintered pads will actually grind down the discs and overheat tho brake fluid
EBC Carbon (natural) pads last longer than stock but give a stock feel.
  • GuyGraham
Posted June 17, 2014 - 08:44 AM
Not in my experience
The amount of heat generated has nothing to do with whether the pad is sintered or not.
Heat generated is the result of friction (whether it comes come a sintered pad or organic) - its the conversion of kinetic energy into heat energy by the brake pad/disc friction
Sintered pads are generally higher friction rated so this maybe where you believe they generate more heat
I've never seen a HH rated organic pad
Lots of OE pads are sintered anyway
I always use DP pads in normal compound (GG)
No brake fade
No brake dust
Kind to discs
It is generally acknowledge that the OE pad will last longest and cuase least wear to the disc, as the compound is developed in conjunction with the disc material, but they cost more than an aftermarket pad
My OE pads (front) lasted 5K miles
My OE rear pads lasted 4.5K miles
I replaced them with Dunlopad DP pads and both are still in there with the bike now having 7.5K miles, but I can tell they won't match the OE mileage
Posted June 17, 2014 - 02:22 PM
I was quoting from memory EBC's packaging explanation of their products
  • GuyGraham
Posted June 18, 2014 - 09:31 AM
EBC organic pads were some of the worst I've ever used - terrible fade, and loads of dust. Even they went over to sintered
DP pads have a sprayed on ceramic heatshield, to prevent heat transfer from the pad to the piston and hence into the fluid
Never had DP pads fade, not even on trackdays on my SV1000, at heavy braking circuits like Mallory Park & Anglesey
To the OP, you won't go wrong with modern sintered pads or OE pads
  • RMK800
Posted June 18, 2014 - 04:30 PM
Have you seen the problems KoolAide mentions with long down hill ride with breaks over heating with sintered pads? I haven't seen that issue, but I'm not sure if I have ever checked. I try to use engine breaking as much as possible then my brakes. As I mentioned I prefer the sintered over stock, atleast in my experience.
  • ManilaMike
Posted June 18, 2014 - 04:32 PM
Thanks for the wealth of info gents. TT truly has the best members.
  • DeepPurplishBlue
Posted June 18, 2014 - 05:35 PM
Agree with the comment about EBC pads...   was not impressed at all for the reasons mentioned.
Stock pads last forever but the braking action and feel is not optimal.   Sintered pads brake much better but as a
result they wear out faster.   Something has to give in exchange for the better braking and in this case it is the
pads.   Better the pads than the rotor...
Have had brake fade with sintered pads but only on extremely long downhills where engine braking alone is not
enough to control the speed of the bike.
  • GuyGraham
Posted June 19, 2014 - 11:10 AM
Never had brake fade, either on dirt or on the track, with DP pads
Track bike front discs have been blue from the heat and not faded - deep blue indicates disc temps of 300°C (600°F) plus
Never had the discs on the WR even start to dis-colour (indicating heat) let alone fade, which means they aren't getting past 200°C.
Most brake fade comes from brake fliud that hasn't been changed and has absorbed moisture, which once the fluid reaches 100°c, starts to boil , creates gas and results in a spongy lever
  • ManilaMike
Posted June 19, 2014 - 07:57 PM
Change brake fluid..... Check. Saw those rotors, not expensive at all.... Next paycheck dreams are being made.
