What side (left or right) do I mount a radiator fan?
6 replies to this topic
  • Rusty99
Posted June 12, 2014 - 08:35 PM
Hi guys,
I'm mounting one computer fan to my 2012 WR 450. Which radiator, left or right side should I mount it? I suspect that a particular side might be effective? My bike overheats constantly so hopefully this helps.
Also is there a thread that shows someone who's done a fan with a on/off switch? I would also like to install a temperature gauge if that is possible.
Thanks
Russ
  • Speedfreak87
Posted June 13, 2014 - 05:39 AM
On my 2006 WR450 I had to install a 120mm fan on the right side because on the left there is just no space to install it properly.
I dont know if the 2012 model has the same "problem" here..........
  • stevethe
Posted June 13, 2014 - 07:02 AM
Hum I wonder what they do to the WR450's down under that come street legal. The bikes get hot sitting in traffic and no fan.
  • Krannie McKranface
Posted June 13, 2014 - 07:39 AM
Proper jetting/mapping and intake/exhaust mods usually prevent all over heating, if you use non-water coolant and a 1.6 bar cap.
If you do rides with lots of clutch slipping, then you will need a fan and possibly even larger radiators.
If the motor and tuning is stock, a fan is  required, but does not solve the problems...of running lean/ hot, just prevents overheating.
  • AaronS
Posted June 14, 2014 - 11:57 AM
I installed the fan on my 2012 on the right side radiator and just use an on off switch for now. Its attached to the Yamaha branded radiator guards. I did have to grind some of the side plastic away so the fan wouldn't hit anything. The fan I used was also not a computer fan. I believe it was a spal brand fan.
Aaron
  • Tro1086
Posted June 14, 2014 - 12:10 PM
A computer fan, that should last a while on a dirtbike hahaha!
Posted June 14, 2014 - 03:45 PM
Yeah, a computer fan will work for a month or two, if you are lucky.
You need a motor with bearings, not bushings, and one that has a motor that floats in the frame.
...hence, all the kits.
