Worn chain slider
5 replies to this topic
  • dan_Rekito
Posted January 17, 2002 - 07:09 PM
Just did a full inspection on the bike. Slight abrasion on the swingarm from the chain slider. The slider itself is worn 3\4 of the way through. 11 months time on bike. I bought a new one yesterday and plan to insulate the swing arm from the slider using 1\32 rubber sheeting. Iv'e been using a
Regina "X" ring chain. I looked on the CR450 F posts and they have alot of chain slider and slap problems too.
  • meangreen75
Posted January 17, 2002 - 07:20 PM
I've had mine for two years now and no probs. Just kept it adjusted and lubed. It's sweetness.
  • Guest_Guest_*
Posted January 17, 2002 - 09:27 PM
I am on my 2nd one in 3 yrs and find it hard to believe that I can get a REAR AND FRONT fender for about 30bucks but one of these little rubber THINGYS is the same price as both fenders!!!?? :)
I am in the process of experimenting fixing my current one that has just BARELY worn thru.
I have taken an old FLY HD tube that was toast and cut out a section, traced the slider onto it and cut out with a simple pair of scissors! (believe it or not the scissors (wife's) worked much quicker and more xact than my carpet knife)
I JB welded the tube piece to the slider and trimmed the edges (only for looks) and it seems as if it is going to work great! :D
Hopefully saved me 30bucks and recycled a tube that was headed for the dumpster!
:D
(If I recycle does that make me a TREE HUGGER COMMY BASTARD?)
PS
check the other side of the swingarm.
Mine and my friends 00' Wr was worn from just the rear brake hose! :D
Not a lot but definately noticable.
Towards the front of the swingarm between the plastic guide and the front.
I may affix a piece of the tube to the SA to keep any more DMG being done by the HOSE.??? :D
[ January 17, 2002: Message edited by: THUMPIN' ROCK HUCKER ]
  • Mr._Bandicoot
Posted January 18, 2002 - 03:21 PM
dan,
The chain sliders on most YZF's wear the swingarm and have chain slap. I had this problem on my 250f untill I removed all of the retainer washers that hold the slider on and modified them. All you have to do is remove the retainers, take a 14mm socket and hammer the outter lip down into a mushroom shape and re-install. This will eliminate the wear on the swingarm and the chain slap because the slider is now tight on the swingarm and can't move around.
Band...
  • motoman393
Posted January 18, 2002 - 04:45 PM
http://mx393.tripod.com/swingarm.html
BTW the foam I used under the slider lasted about 3 months and I have since then replaced it with an old HD inner tube and it works great!
  • Wyatt
Posted January 18, 2002 - 07:53 PM
I removed the retainer washers and bolts, and lifted up the chain slider. I placed a bead of clear silicone under the chain slider. I then placed a rubber o ring on each retainer washer before installing it. The o ring took up the slack in the bolts. The chain slider is now securely in place and the bolts hold it down tight. = no more wear on swingarm
  • Hot  30 replies
  • Hot  113 replies
  • Hot  36 replies
  • 10 replies
  • Hot  50 replies
