04 wr450 surging
36 replies to this topic
  • x_JT_x
Posted June 07, 2014 - 01:33 PM
Just went on my first ride with my 04 wr450f. It's having an issue where it surges any time it's past idle, unless you rev it quickly. Seems like a constant rev limiter everywhere. Also is sucking gas WAY faster than the other 3 I am riding with. Playing with the air screw changes it a little but can't eliminate it. Idles highest with air screw ALL the way in if that helps.
Mods done are only the pipe tip. Not airbox, maybe not even rejetted but I can't know for sure. Riding at 4k feet. Will be ridden between 2-6k mostly. Any advice on how to fix?
  • Krannie McKranface
Posted June 07, 2014 - 02:19 PM
You have to get into the carb and determine the jetting
It sounds like your pilot is too big: you want a 45
The minor surging at partial throttle is part of a known problem with all Wr's. The ignition module wanders at certain rpms.
You can reduce it by unplugging the TPS harness
Read the FAQ section at the top of the forum.
  • flyandride
Posted June 07, 2014 - 04:42 PM
That's a fuel screw.  Turning it in makes it leaner.  If you need it all the way in, the pilot jet is too big.
  • x_JT_x
Posted June 07, 2014 - 06:13 PM
Dropped the needle two notches and most of it seems better. Still has it under half throttle
Posted June 07, 2014 - 07:09 PM
Yes, if you search 'stuttering' or 'surging' or 'rough running' in this forum, you will have enough reading for a year....
  • x_JT_x
Posted June 07, 2014 - 08:09 PM
Yes, but I am by no means good with jetting so I did what the forum is made for and asked for help. I basically want to know what jetting should be for previously posted elevation, opened airbox and gytr pipe tip as that is what I will be doing (already has the tip)
I'm well aware there is enough reading and almost none of it is relevant to my issue. If it's a known issue someone should do a write up, lots of great people who could I'm sure.
  • x_JT_x
Posted June 07, 2014 - 08:11 PM
Apparently the guy I got it from thought it was the tps because it was already unplugged. I plugged it back in since it made No difference.
  • MANIAC998
Posted June 08, 2014 - 12:48 AM
Not only do I think your pilot is to large, but I'm guessing your float's are off too. Since you mentioned that your burning WAY more fuel than your buddies.
  • x_JT_x
Posted June 08, 2014 - 06:10 AM
The rider behind me said that it smelled like a two stroke burning especially when I was riding in that misfire spot. It doesn't drip gas at all, and if the pilot were to big would I be able to one kick it? My battery died out near the end and it's a piece of cake to start up.
  • x_JT_x
Posted June 08, 2014 - 06:11 AM
Oh and by the time we did like 20 miles I hit reserve and they had over half a tank.
Posted June 08, 2014 - 04:08 PM
If the floats were to high, it would stall or  hesitate on rough terrain, and you would be loosing fuel out the overflow
Easy enough to check....find some stairs....
  • x_JT_x
Posted June 08, 2014 - 07:06 PM
Dumps no fuel. Does it on smooth or rough terrain the same.
  • MANIAC998
Posted June 09, 2014 - 12:25 AM
Well, that fuel is going somewhere. And I can't imagine it being burned.
Posted June 09, 2014 - 06:03 AM
I bet it's the emulsion tube (needle jet) that has 'ovaled' (worn) out, causing a large amount of un atomized fuel get into the motor at certain throttle positions
  • x_JT_x
Posted June 09, 2014 - 07:49 AM
You can smell it burning really uncleanly at that rpm range. Dropping the needle for the most part fixed it. someone had raised it after doing a pipe without doing the airbox.
  • x_JT_x
Posted June 09, 2014 - 07:50 AM
The needle was on like the 3rd from the bottom clip. It was pretty dang high. Bike only has about 500 miles on it according to the odometer and the condition of it.
  • x_JT_x
Posted June 11, 2014 - 09:22 PM
Got a chance to pull the carb apart today. It's got a 165 main jet 45 pilot 65 other jet. Now I'm confused because I was expecting a big pilot jet. Need some advice, is any of this jetting wrong?
Posted June 12, 2014 - 05:19 AM
main
pilot
starter
All normal
Change your plug
Unplug your TPS
Do a stator resistance test per the service manual
  • x_JT_x
Posted June 12, 2014 - 09:12 AM
main
pilot
starter
All normal
Change your plug
Unplug your TPS
Ok. What clip should the needle be on? Dropping it 2 almost cleared up the miss, but left just a tiny bit at the bottom.
Is that jetting right for the airbox mod? I just cut the snorkel out while waiting for a response here.
Posted June 12, 2014 - 11:33 AM
yes
