Yamaha YZ450F top speed of 90MPH + Is it possible?
38 replies to this topic
  • slotracer577
Posted July 01, 2014 - 06:51 PM
#21
With the right gearing, no problem. One bigger in front, then as small as you can in back. I think I ran a 36 or 38 on my Wr when I road raced it. I never had a gps on it, but it would run with sv650's.
  • YzCas
Posted July 02, 2014 - 04:27 AM
#22
mine dam near runs it with two down in the back and gets there fast.
  • rhinoracin
Posted July 03, 2014 - 10:34 PM
#23
I remember seeing a 450 comparison from 2012 or 2013 in Dirt Rider that said all the new MX 450s had a top speed of 90-100. I dont know how they came up with that
Posted July 05, 2014 - 09:05 AM
#24
Mathematically, assuming the ability to hit the rev limit under a 5th gear load and zero tire slip, they all do top out between 90-100.  Realistically, however, they will run out about 10mph slower than that.
  • Yz54
Posted May 01, 2015 - 10:19 PM
#25
Hi Guys I road race a 2012 Yz450f supermoto and have been clocked through the speed traps at Phillip Island in Australia at 199kph will try for the 200kph at the end of May
  • stevethe
Posted May 02, 2015 - 06:38 AM
#26
That's pretty fast is the bike built or have a faring or is it down hill.
  • Yz54
Posted May 02, 2015 - 02:49 PM
#27
It has no fairings apart from the original plastics and supermoto front guard and wheels special exhaust and a high comp piston still a 450 running 16-40 gearing, dyno runs to get the power and an absolute gem to race you can see some pics on facebook Axle Armor Tracksliders
  • Wiz636
Posted May 04, 2015 - 08:59 AM
#28
I hit 104 on pavement with my '13 on my way from Alfonsina's to Coco's Corner. I was running 15/48 gearing.
  • x_JT_x
Posted May 04, 2015 - 09:12 AM
#29
I don't know about the '13 but on an 06 that gearing basically ruins first gear. I just picked up an 06 with that gearing and it's nearly unridable.
I don't doubt this bike could break 100 though.
  • Zabrow187
Posted May 04, 2015 - 07:12 PM
#30
I hit 100 yesterday on my 2009 YZ450f Supermoto.  14/40 gearing on 17" wheels
  • WRF-Rowdy
Posted May 05, 2015 - 05:49 AM
#31
Check out my 92mph thread.
That's a 3 years old WR450F with snorkel, racekit muffler with pea-shooter and WR timing(!), going 92mph.
So my (guessed) answer to your thread's main question is: hell, yes of course!
In my previous bike I was running 15:44 (for engine protection on the freeway),
the 2012 mentioned in my thread currently has a 47 at the rear.
But then again it all depends on the amount of wheelspin you'd need at your specific stomping grounds to go that fast.
Edited by WRF-Rowdy, May 05, 2015 - 05:51 AM.
  • WRF-Rowdy
Posted May 20, 2015 - 09:38 AM
#32
To my shock I found out that I'm running 13:47 when doing 92 mph.
I hate the noise from the 13 teeth sprocket. For road commuting I'll go with a 15 teeth.
  • atomic410
Posted May 21, 2015 - 10:26 AM
#33
guys racing supersingles can easily keep up with sv's.  i dont think 100 would be hard at all.  IIRC I ran a 15 38 on my supermoto last time I road raced it at MAM.........and won..........I miss that bike
  • stevethe
Posted May 22, 2015 - 06:15 AM
#34
The fastest road race winning built to the hilt 09' YZ450 is in the 120+ MPH that I know of. It produces some serious dyno numbers as well and cannot run on pump gas.
Posted May 22, 2015 - 06:23 AM
#35
If you're talking built engines, then it's no problem.  A good YZ450 flat tracker should hit 100 on a half mile oval.
  • Bennyb450
Posted June 15, 2015 - 05:11 PM
#36
+1 on the front will get you into the 90's. Stock will do mid to high 80's.
  • Bennyb450
Posted June 15, 2015 - 05:13 PM
#37
Agreed. I've had two 426's and now an 03 450. 15/48 gearing flywheel weight 18" rear.
  • slotracer577
Posted June 23, 2015 - 06:36 PM
#38
Just needs the right gearing. I raced a 426 in a tz125 with my Ducati 900 and the 426 walked away.
Edited by slotracer577, June 23, 2015 - 06:40 PM.
  • n16ht5
Posted June 24, 2015 - 07:33 AM
#39
WR 1st and 5th on my 07 YZF I hit 95mph and could have squeezed a few more if I had room. 14t front sprocket stock rear (50?)
