Lighting help
2 replies to this topic
  • Klim1972
Posted June 06, 2014 - 11:41 AM
I have a 01 yz426 that I wanna put a headlight on and a battery in airbox . My question is can I charge Battery off of stock bike system and how would I wire it if so
Posted June 06, 2014 - 02:04 PM
The answer is "no, you can't".  The system was designed to support ignition only, and has no surplus energy to put into the project.
Converting to the stator/flywheel from a '98-'02 WR400/426 is the most practical way to approach the matter, but you will need to modify the stator to be run with the YZ ignition system, and you'll need a rectifier and regulator to charge a battery.  Searching the site will produce a lot more info.
  • Nick450X
Posted June 08, 2014 - 05:28 AM
Klim
Pro-racing in the UK have all your needs for the yzf 01 :ride:
  • Hot  50 replies
  • 5 replies
  • Hot  36 replies
