wr 426 hot spot on crank should i split the case
23 replies to this topic
  • john munt
Posted June 01, 2014 - 06:14 PM
was sitting at a light it was about 105 out bike shut off with slight back fire let it cool down started to kick it over felt slight metal to metal binding but  it started shut it off because of that got it home tore down the top end this is what I find should I split the case and replace the bearing ? anything will help
Edited by john munt, June 01, 2014 - 06:16 PM.
  • SellYour4Stroke
Posted June 01, 2014 - 06:29 PM
Is the rod moving smoothly and freely? That's actually normal discoloration from heating during factory assembly...looks like they replaced the other crank half.
Does the motor rotate freely or does it bind?
  • john munt
Posted June 01, 2014 - 06:33 PM
rotates freely no binding
  • SellYour4Stroke
Posted June 01, 2014 - 06:37 PM
There's a side clearance measurement for your rod, might as well give that a check too.
How about when you kick it over? If so, pull your clutch cover.
How's your piston/cylinder? it's possible it may have heated to the point of seizure as well.
Edited by jeffdanger, June 01, 2014 - 06:39 PM.
  • john munt
Posted June 01, 2014 - 06:50 PM
everything else looks great besides the valves having normal carbon build up checked the rod play its were it needs to be the barrel has no scaring needs a set of rings though piston is in good shape no sign of over heating there but since I have it off going to put the wisco set in just for good measure just was not sure about that heat spot just didn't look right all I can think now is that the decomp must have got stuck due too it getting hot and probably would not hurt to put a new water pump in
  • john munt
Posted June 01, 2014 - 07:10 PM
you think it will be ok ?
  • SellYour4Stroke
Posted June 01, 2014 - 07:13 PM
Does it feel like it binds when you kick it over?
There may be someone else with some more insight. I'd give them a chance to answer as well.
  • jamracing
Posted June 01, 2014 - 07:37 PM
If you use it for street riding, I would recommend a fan kit to keep that air flowing at the traffic lights...
  • john munt
Posted June 01, 2014 - 07:44 PM
there was slight binding when I first tried starting it but after it ran and tried starting it a second time it was gone but I didn't want to ride it without taking the head off and taking a look inside and that is what I hade found which made me come to the conclusion that maybe the barring might have been going causing it to heat up on the one side in turn making it slightly weld itself to the piston rod but with no heat discoloring to the piston rod makes me think that it is the bearing being scared but again not sure thanks for your feed back
  • Beau 88
Posted June 01, 2014 - 07:45 PM
I would say that's normal from crank manufacturing , but it's only on one side . Are those cranks machined solid with one web welded on ?
  • Beau 88
Posted June 01, 2014 - 07:47 PM
I honestly don't know i'd like to though ,  :thinking: Obviously you have damage somewhere i would rebuild it if i were you , of course if you have the funds but you are halfway there now . It probably had a small seizure, that i couldn't imagine getting any better by just putting it back together with new gaskets.
Edited by Beau 88, June 01, 2014 - 07:54 PM.
  • john munt
Posted June 01, 2014 - 07:51 PM
solid
  • SellYour4Stroke
7u77hb2.png?1?5387Multi piece. My guess is they heat the daylights out of them so they can assemble them quickly.
I would LOVE to work in a YZ manufacturing plant.
  • john munt
Posted June 01, 2014 - 07:57 PM
in that case shouldn't the other side have the same discoloring ??
  • john munt
Posted June 01, 2014 - 08:03 PM
I think your right beau 88
  • Beau 88
Posted June 01, 2014 - 08:04 PM
That was my point :) and reason for saying more investigation is needed and if i took it all apart all the bearings would be replaced .
  • SellYour4Stroke
Posted June 01, 2014 - 08:05 PM
Correct...unless it was replaced with a new one. I'm not sure it's common, but I remember doing it with some 250R fourwheeler cranks back in the day with some broken off flywheel threads. I've also heard of some of those older thumper cranks cracking.
To reassemble them, you don't have to heat them til they're blue...i was sayin...the factory probably does it that way so they can do it in 12 seconds
EDIT: I agree though...I'd keep investigating...clutch cover...
Edited by jeffdanger, June 01, 2014 - 08:07 PM.
  • Beau 88
Too lazy to look it up right now , thanks  :p
  • john munt
Posted June 01, 2014 - 08:09 PM
hmmm now I am  really thinking :banghead:
  • SellYour4Stroke
Posted June 01, 2014 - 08:12 PM
If there's such thing as dirt bike nerds...we are them.
