shifted to second, thats all she wrote.
6 replies to this topic
  • worleybird81
Posted June 01, 2014 - 05:15 PM
Just rebuilt my 06 450. Intake valves were shot, so replaced those and figured since had it apart that I would throw in a new piston. My first time on a four stroke rebuild. I had the shop do my valve work and I was meticulous about every thing I did. Thought I had it until I shifted to second, and bang just quit. Anybody have any ideas?
  • Slow and Jerky
Posted June 02, 2014 - 04:08 AM
Does it kick over or did it seize?
  • dadat40
Posted June 02, 2014 - 01:18 PM
Take it apart and see where you went wrong
  • worleybird81
Posted June 02, 2014 - 04:57 PM
Kicks over, pulled valve cover and my intake is off 90 degrees
Posted June 03, 2014 - 08:08 AM
Check the cam and caps for signs that it seized.  It is not difficult to deform a cam cap by seating them forcibly, torquing them excessively or out of sequence, that sort of thing.  The cam chain was replaced when you did the build, no?
  • worleybird81
Posted June 03, 2014 - 05:51 PM
Thanks Gray racer513. Did not replace the cam chain, and my torq and sequence was by th book. Signs that cam has seized???
Posted June 04, 2014 - 06:44 AM
Yes.  If the bearing surface under the cap is galled/scored badly, your cam may have seized.  But it's also possible that the chain has a tight link or two that caused it to slide and throw your timing off that way.  Either way, it should not be trusted after a timing slip.  Replace it, and the tensioner, too.
  • 0 reviews
  • 9 replies
  • Hot  113 replies
Motocross
  • Hot  491 replies
