What is the proper thing to do for a flooded engine? YZ426F 02
8 replies to this topic
  • the_trademark
Posted May 29, 2014 - 07:38 AM
Hi fellow bikers.
I have a simple question. When i fall or if it stalls for any reason almost every time it floods and i have serious trouble starting it. Every time i try different things with the hot start, choke and decompression lever but i havent found the right way to resart it. Can you please tell me the proper procedure to do? :)
Edited by the_trademark, May 29, 2014 - 07:39 AM.
  • seacraft69
Posted May 29, 2014 - 09:13 AM
When my 06 stalls I just hold the hot start open for a couple seconds before and while kicking. Usually 1 or 2 kicks and I'm off.
  • Yz400f Jeff
Posted May 29, 2014 - 10:54 AM
Hold the compression release open, kick it abunch of times to clear it out.
  • Ryan Parker
Posted May 29, 2014 - 10:57 AM
If flooded hold the gas wide open while kicking.
  • mx5112002
Posted May 29, 2014 - 12:47 PM
+1 lots of fuel needs lots of air.
  • 90atk
Posted May 29, 2014 - 03:02 PM
i thought on these bikes you were never suposed to hold the throttle open while trying to start it?
  • 90atk
Posted May 29, 2014 - 03:04 PM
this is what i do. second bike down is for the yz426f
http://www.dirtbikem...34C8D98BEAD7C6B
Posted May 29, 2014 - 05:11 PM
It won't very likely start that way in any case, but using the compression release, and holding the carb open at the same time you kick the engine through will blow out the excess fuel that's flooded the engine without drawing in any new fuel in the process.  That's because there won't be enough air moving through the carb fast enough to create the necessary vacuum to raise fuel up through the jets.
This can also be done with auto decompression engines, but just turn it through slowly while doing so.
It may also be useful if the engine still acts flooded to open the throttle between 1/8 and 1/4 while cranking.  The extra air will get it going.  Just be aware there is a potential for it to kick back rather viciously.
  • cr250boyy
Posted June 24, 2014 - 05:11 AM
when i had a 2002 426 it was a dog to start after it flooded and if you hold the throttle open it will near break your leg if your not careful
  • Hot  36 replies
  • Hot  113 replies
  • Hot  28 replies
  • Hot  30 replies
