2008 YZ450 - locked her up
27 replies to this topic
  • nucular
Posted May 28, 2014 - 04:13 AM
I was doing some trail riding this past weekend and was coming up to a small hill in 2nd when the engine just immediately shut off and locked up.  I was able to push the kicker down once but once it came back up, it was stuck.  I bought this bike last summer and the PO could not tell me how many hours were on it.  Everything looked great - clean oil, clean radiator fluid, good chain, good valve clearances.  I checked everything and put an hour meter on so I would at least know how many hours I have put on it.  It always ran strong and no out of the ordinary noises as far as I could tell.  I have put exactly 6 hours on it this spring.
Now, to be honest, I found some magnetic shavings in the filter the last time I changed the oil.  Not a lot but enough to show up on my magnet pen.  I was hoping maybe transmission gears or something.  Just a small amount, no gold flakes or anything.  So my mistake, I should have probably torn it down immediately.
Anyway, I started the tear down last night.  I have not removed and split the bottom end but the head and cylinder are off.  The head looks fine, the cylinder has a small scratch on the exhaust side (I'm not sure if it is from this incident or not) but the rod does not spin freely on the crank so at least the big end bearing is shot.
Not knowing how many hours were on the bike, I think my plan is to just go ahead and replace the crank with a new OEM one, do a cylinder/piston swap from MT, and replace the cam chain.  Is there anything else I should do while I am in there?
Here is what I found in the filter cavity:
Posted May 28, 2014 - 06:08 AM
Have the cylinder inspected and measured.  It might be alright.
The chips in the second picture do definitely look like bearing flakes.
  • nucular
Posted June 04, 2014 - 06:45 AM
OK, I should be splitting the case this weekend.  I haven't disassembled the head yet but I have not had any valve issues so i'm hoping that is OK and I only need to do the bottom end, piston, and maybe cylinder.  I think right now my plan is to R&R the following:
OEM Crank
Crank Bearings
transmission Bearings (4)
transmission oil seals and O-rings
bottom end gasket kit (includes many seals and orings)
top end gasket kit
cam chain
water pump oil seals and bearing
oem piston/rings/pin/circlip
possibly an oem cylinder depending on how mine cleans up
My questions are:
1) Does this sound like overkill or is this all the proper stuff to do?
2) I plan on reusing all of the circlips for things like the oil pump, kick shaft gear, etc. so hopefully that is not a bad idea.  It's only another $5 or so if I did replace them all.
3) The bottom end gasket kit has a note about other things that need replaced and it lists the 'water pump' and 'oil pump rotors'.  Are those commonly replaced during a bottom end build?  I was planning on reusing both.
4) If I do have to have the cylinder re-lined or replaced, would it be best to just buy a new OEM cylinder?  It seems like the cost to buy the OEM standard size cylinder, piston, rings, pin, and circlips is around $385 which is less than an athena replacement.  Doing a Millennium Tech cylinder replacement even seems more expensive than just buying a new one.  MT wants $215 + shipping for a cylinder swap and you can get an OEM cylinder for less than $250.
5) I'm looking at at least $700 in parts (not including a cylinder).  The rest of the bike is in good shape IMO.   Is this worth it or would I be better off parting it out and getting another one?  I had considered that but I would still be buying used which is always a gamble.  At least this way, I know that the motor is practically new.
Posted June 04, 2014 - 07:03 AM
  1. Don't forget the chain tensioner
  2. You can reuse most of the circlips other than the piston clips IF they are are not even slightly deformed by removing them.  Be critical.
  3. The bottom set does not include the crankshaft oiling seal, the water pump seals, output shaft seal, or clutch arm seal.  These should be replaced.  The oil pump needs to be inspected and evaluated.
  4. Most of the time with the 450's, it's near the same price to buy new OEM as opposed to replating, so that's how I roll it.  Might as well be new.
  • nucular
Posted June 04, 2014 - 07:23 AM
Thanks, Gray.
So I should replace the ACCT?  It looks like those run another $60 or so.  Here is my full list. I tried to go through the manual and identify everything they have marked as needing replaced and then I tagged the ones that were included in the bottom end gasket kit with an XXXX.  I'm leaning toward doing the rebuild.  $1000 (including the cylinder) or so doesn't seem bad since the bike is in pretty good shape overall.
Cover Gaskets
    XXXX 5TA-15453-00-00 clutch cover gasket ($10)
    XXXX 2S2-15462-10-00 crankcase cover 3 ($13.25)
    XXXX 2S2-15451-00-00 crankcase cover 1 ($8.57)
Crank
    crank - 2S2-11400-01-00 ($300)
Crank Bearings
    crank bearings - 93306-30633-00 ($40 X 2)
Cam Chain
     94591-57118-00 Chain ($18)
Oil Cleaner
    XXXXX 93210-47675-00 O-Ring ($4.25)
    XXXXX 93210-07135-00 O-Ring ($3 X 3)
Transmission Bearings:
    93306-20532-00 ($25)
    93306-00431-00 ($16.50)
    93306-00426-00 ($16.50)
    93306-205A5-00 ($24)
Transmission Seals/Orings
    XXXX 93102-32480-00 Oil Seal ($8)
    XXXX 93210-22298-00 O-Ring($5)
Gaskets
    bottom end gaskets - 5TG-W0002-00-00 $50
    top end gaskets - 5TA-W0001-00-00 $50
Water Pump
    93109-11073-00 Oil Seal ($8)
    93102-12321-00 Oil Seal ($7)
    93306-00105-00 Bearing ($11.15)
    XXXX 93210-19758-00 O-Ring ($3)
    XXXX 5BE-12439-00-00 O-Ring ($10.50)
    XXXX 90430-06014-00 Gasket ($3)
    XXXX 93210-16500-00 Water Pipe O-Ring ($5)
Oil Pump
    93440-10153-00 Circlip ($1)
    99009-12400-00 Circlip ($1)
Balancer
     90215-14287-00 Lock Washer ($4)
    90208-25045-00 Primary gear washer ($8.50)
Kick Shaft
    93410-20038-00 Circlip ($1)
    99009-16400-00 Circlip ($1.25)
    99009-20400-00 Circlip ($1.25)
    XXXX 93102-20108-00 oil seal ($7.25)
Misc
    XXXX 93210-10197-00 O-Ring ($4.25)
    XXXX 93210-08003-00 crankcase cover o-ring ($3)
    XXXX 90430-08119-00 drain bolt gasket ($3)
    XXXX 90430-06014-00 drain bolt gasket ($3)
    XXXX 90430-10188-00 drain bolt gasket ($3)
OEM Cylinder - 2S2-11311-11-00 ($238.55)
OEM Piston - 2S2-11631-20-00 ($95)
OEM Piston Rings 5JG-11603-00-00 ($33)
OEM Piston Pin - 5TA-11633-00-00 ($16)
OEM Piston Circlip  93420-18082-00 (.61 X 2)
Posted June 04, 2014 - 08:00 AM
I didn't see the crankshaft oiling seal (93101-14164-00 ) on your list.  The first three cover gaskets you listed are included in the bottom end set.  In fact, you have quite a bit of duplication going on there.  Yamaha's online fiche shows the contents of the two kits on the Alternate Parts; Gasket Kits page.
http://www.yamahamot...t.aspx?ls=sport
here's the list:
  • nucular
Posted June 04, 2014 - 08:12 AM
here's the list:
Hmmm... not sure how I missed the crank seal. thank you.
Yeah, everything that is preceded with an XXXX is included in one of the two gasket kits.  I didn't include them in my cost.  I just wanted to make sure I had everything listed out.
  • nucular
Posted June 05, 2014 - 03:10 PM
OK, last question I hope.  I split and disassembled the crank case and realized I was about 4 bearings short on my list.  There are a total of 10 bearings in the cases.  I missed:
balancer bearing - 93304-20310-00 (2 of these)
shift cam fork bearing 93306-90509-00
shift cam fork bearing 93306-80501-00
I presume I should knock out all of the bearings and replace them all, right?  My plan was to remove the bearings, clean up the cases in the dishwasher on hot, hand clean all of the gears, etc, and start the install/reassembly process.
Posted June 05, 2014 - 04:09 PM
There's rarely a need to replace the shift cam bearings, but the balancer shaft bearings do lead a tough life.
If I had ever even spoken openly about cleaning parts in the dishwasher, I would not be here now.
  • dirtbeater
Posted June 05, 2014 - 05:14 PM
Cleaned a q-jet carb in my dishwasher. Worked great. Just about ruined the dishwasher. Makes wife's really happy.
  • nucular
Posted June 06, 2014 - 04:17 AM
Well, the plan was to clean it off with some simple green and a hose first and then use the dishwasher to finish it up.  I was also planning on sticking the cases in the oven to try to pop some of the bearings out so as long as I don't break the stove or dishwasher or stink up the house, I shouldn't take too much heat.  Our dishwasher is on its last leg anyway.  She may thank me.
Posted June 06, 2014 - 06:35 AM
Using an oven, or even a gas grill with a thermometer on it (if you keep an eye on it) is a good way to manage the removal and installation of bearings, and even the crank, but be careful.  Keep the heat between 220-275, no higher.  Heat the cases for 15-20 minutes at that temp to even out the heat distribution in the part.  Repeat this when it comes time to install the new bearings, having placed the bearings in the freezer for at least 20-30 minutes and they'll drop right into their pockets.
  • nucular
Posted June 06, 2014 - 06:41 AM
Have you found that you can easily get that bearing out that sits in a blind pocket with this method?  I was planning on renting or buying a blind bearing puller.  Also realized the clutch mechanism hides a little roller bearing down in there.  I'm hoping I can extract and re-use that one as well.
  • dirtbeater
Posted June 06, 2014 - 08:15 AM
I will recomended not using the dishwasher. Buy a new one first and put the old one in the garage. It is a pretty hillbilly parts cleaner, but it does work. My entire house stunk of old gas for days.
  • nucular
Posted June 06, 2014 - 08:51 AM
Did you scrub the case out with gas before you put it in the washer? I sprayed mine out with simple green and rises it so it is already pretty clean. I was just planning on letting the soap do it's job and get it spotless.
Did you scrub the case out with gas before you put it in the washer? I sprayed mine out with simple green and rinsed it so it is already pretty clean. I was just planning on letting the soap do it's job and get it spotless.
Posted June 06, 2014 - 01:59 PM
So that you can fill it back up with motor oil?  Very well.  No reason to do that.
Yes.  The bearing you're wondering about is the left side main shaft bearing, which sits in a blind pocket, with the case heated, wearing gloves, slamming the center joint surface down on a flat sheet of wood, like the top of a wood work bench, will usually pop it out.   Again, don't exceed 275 ℉.
  • nucular
Posted June 06, 2014 - 02:03 PM
True. I suppose that's overboard. With all the bearings out and the hose down I'm sure all the bearing shards are gone.
  • nucular
Posted June 10, 2014 - 04:48 PM
Does anyone know what the torque value is for the idler gear shaft Oil Pump Drive Gear shaft?  I don't see it in the manual.  The gear just sits on the shaft which is bolted to from the inside of the case.  Also should I use red loctite for the bearing retainers?  The manual just says loctite.
Edited by nucular, June 10, 2014 - 04:58 PM.
Posted June 10, 2014 - 09:13 PM
That value is listed on 2-11 as "oil pump drive gear shaft": 7.2 ft lb/86 in lb/10 Nm.
Use red Loc-Tite, and use it on the retainer screws, too.
When using Loc-Tite, two things are important.  The threads have to be clean and oil free.  Use carb spray, then brake cleaner.  The other thing is to give it the full cure time on the label so oil doesn't degrade it before it sets up.
  • nucular
Posted June 11, 2014 - 04:29 AM
Thanks once again, gray. I had tried cleaning them up with carb cleaner but it didn't do much. I'll try some brake cleaner too. Would it be worthwhile to try running a bolt or tap through with the brake cleaner?
  • On January 15, 2017
  • Hot  113 replies
  • 9 replies
Motocross
  • Hot  491 replies
