shift lever wont come off
11 replies to this topic
  • theyzdude
Posted May 27, 2014 - 08:52 AM
Hey all, I have a 2009 yz450f. I was trying to take my shift lever off. I took the bolt out and it still wont come off. Any help would be greatly appreciated.
  • theyzdude
Posted May 27, 2014 - 09:25 AM
I'm not sure if I posted this in the right section of not.
  • cowboyona426
Posted May 27, 2014 - 09:42 AM
It'll come off, just keep trying.  If need be and space allows wedge a screwdriver in the slot just slightly to spread out the splines enough to get them to release a bit.
  • theyzdude
Posted May 27, 2014 - 10:16 AM
Cowboyona426 I tried the screwdriver also. I will try again when I get home.it moves on the shaft but it won't come off the end.
  • theyzdude
Posted May 27, 2014 - 12:05 PM
Tried again and I didn't do any better than last try.
  • cowboyona426
Posted May 27, 2014 - 01:41 PM
I've never had one fight that bad.  Try some penetrating oil between the shifter and the shaft?  And just to be 100% sure, did you take the bolt completely out?
  • theyzdude
Posted May 27, 2014 - 03:07 PM
Yeah I did take the bolt completely out. It almost acts as if the end has expanded. I will try some penetrating oil.
  • theyzdude
Posted May 28, 2014 - 08:53 AM
WD-40 didn't help much either. It moves on the shaft easily until I go to take it off the end.
Posted May 28, 2014 - 09:08 AM
t355_eea631f15467ce12ac106805eb0302e5.jp
  • cowboyona426
Posted May 28, 2014 - 10:19 AM
That'll make short work of it.
  • DirtyMan
Posted May 28, 2014 - 03:01 PM
Sounds like the shaft end may have gotten mushroomed . After you get it off file a chamfer around the shaft.
  • theyzdude
Posted May 28, 2014 - 04:07 PM
That was my guess to why it wouldn't come off dirtyman.
