2014 YZ450F EXHAUST SYSTEMS.
Brand Yoshimura
86 replies to this topic
  • Drenmaster
Posted April 09, 2015 - 02:16 AM
#81
I just fitted a FULL DR D NS 4 after using a full yoshi for 6 months on my YZ 450 2014
Didnt like the yoshi with the silencer insert, removed that & was way better sounding & power. Is however very abrupt of the bottom, too abrupt in fact mainly out of corners, (stock maps).Also think the yoshi build quality was poor. Where the first join is from the engine, vibrates to the point ive had to re weld the little lug that holds the join in place. Both joins dont seal properly even aft sealing them the hi temp gasket cement, TI syst.After about 30 hrs
Someone PLS  tell me you can remove the silver DR D silencer, (already removed spark arrestor) & how ?
First ride with the silencer in, thought was worse than stock. Felt all chocked up & like it added no benefit !
You can not remove the spark arrestor on the ns4. it is welded in. you could cut the screen but then it would be permanently removed. The stock pipe has better low end. but almost too powerful, the Dr.d seemed to be better mid and top.
  • wes513v
Posted April 09, 2015 - 04:20 AM
#82
Not so. The spark arrestor comes as a separate piece with the pipe and is replaceable by removing the single screw in the end of the pipe. What he is referring to, I believe, is the next piece that appears in the tail of the pipe that the same screw goes through. After looking at it more closely I think this is actually the internal baffle that runs the length of the canister and can't be removed.
Posted April 09, 2015 - 06:22 AM
#83
The spark arrestor in the DRD systems subtracts nothing from the power output in my experience.  In, out, can't tell the difference.
  • 03yzf450-kuke
Posted April 09, 2015 - 11:34 AM
#84
No one use jingle exhausts on there bikes? They look and sound great!
Hindle** damn spell check
  • Envisage
Posted May 04, 2015 - 05:39 AM
#85
Tried some of the DR D maps, one or two seemed better on a hard pack track at cool temperatures
Went back to my home track, (sand) warmer temperatures, (same settings) & was like it had a stutter in it & actually ran worse than stock.
Anyone know what the stock mapping/fuel  is for a YZ 450 2014 model ? presuming its in the manual somewhere but couldn't find it
Posted May 04, 2015 - 06:10 AM
#86
Stock mapping for all EFI YZ's is all zeros.
  • Envisage
Posted June 17, 2015 - 03:21 AM
#87
Im currently running this mapping on my YZ 450F 2014, although is still to abrupt/aggressive off the bottom. Any suggestions on how to smooth/mellow this out ?
Full DR D exhaust, sand tracks mostly, & racing in & around the 20 degree mark
Fuel        Ig
+2
+2
+2
0
0
0
+1
+1
+1
0
0
0
+1
+1
+1
0
0
0
What is the loudest aftermarket exhaust/muffler for a 09 crf230f by 230REVHEAD
  • Hot  60 replies
What Yoshimura exhaust is this? by espacef1fan
  • Hot  37 replies
Modifying RS-4 to fit under rear fender by MotardManiac631
  • 3 replies
So, which team does Grant sign with this week? by cjjeepercreeper
  • Hot  28 replies
Yoshimura Franchise Kit by JP Sporty
Exhaust Full System Exhaust Yoshimura Franchise Kit, Brand Yoshimura
  • Last review by nsky
  • On October 21, 2016
