2006 WR450F. Speedometer Calibration
2 replies to this topic
  • condor74
Posted May 22, 2014 - 02:22 PM
Does anyone know how to calibrate the speedometer on a WR450.  Mine seems to read very low.  I have only had it up to 40 mph a couple times and It seems like I am doing closer to 60mph.  I need to find a way to check it and correct it.  If it is really as far off as it seems, this would throw off the odometer too and I use that more than the speedometer.
Any help would be appreciated.
  • condor74
Posted May 22, 2014 - 02:48 PM
I think I figured it out.  I have actually been searching for the answer for a while on this but never posted anything about it.  In case anyone else wants to know or is having similar issues the way to calibrate the stock speedometer on a 2006 WR450 is hold down slc1 and reset for 2 seconds.  It will bring you to a speedometer calibration page.  From the factory it should read 100.0C.  That is 100% or 0 correction.  You can fine tune it by making runs with a GPS and getting it to match by moving it up or down from 100.0  Incedently mine was set at 65.0 which would be 65% of total error assuming that 100% is correct for me.  That would mean that when I ran my bike up to 42 MPH on the gauge, I was actually doing 65 MPH.  That is about what it felt like.
I hope this helps others.
  • 1trackmind
Posted May 22, 2014 - 02:53 PM
Thanks for the info.
