springs for an heavy guy
12 replies to this topic
  • sathio
Posted May 22, 2014 - 07:39 AM
Hi, I've just bought a 2012 wr450f  so far I love the bike, but I fell that when I'm all dressed and I also have the camel tank for water on my backpack I'm a bit too heavy for the bike.
I'm around 95kg (+-210 pound) what kind of modifications should I do?
  • sathio
Posted May 22, 2014 - 07:42 AM
damn, I picked up the wrong sub forum, can anyone move it? sorry
  • mch
Posted May 22, 2014 - 09:18 AM
Depends on what type of riding, but I'm thinking
Forks: .48-.50 kg
Shock: 5.7 kg
Dual-Chamber Fork Pressure Springs: 1.8 kg or 2.2 kg
Racetech.com has a spring rate finder.  I'm around 250 lbs and I have .50 in the front and 6.0 in th back.  I think you would be fine with 4.8 in the front and 5.7 in the rear.  If you opt to change the Dual Chamber springs, 1.8 would probably be good; I have the 2.2 kg springs in mine.
Edited by mch, May 22, 2014 - 09:19 AM.
  • MidlifeCrisisGuy
Posted May 22, 2014 - 09:47 AM
Tell us more about the dual chamber fork pressure springs, please.  What are they and what do they do ?
  • mch
Posted May 22, 2014 - 12:37 PM
Check this out: http://www.racetech....ressure Springs
I bought my 2012 WR in 2012, but then bought a used 2007 YZ450F in 2013.  When pulling a part the forks on the 07, those innner springs looked hammered.. they were about half the length of normal (would slide up and down along the shaft).  The service manual doesn't talk about it from what I remember.  Also, the 07 YZ and 12 WR forks are basically the same, with the exception of valving.
I serviced the forks recently on the 07 again, and then I saw the plastic reservoir pistons were coming a part (see pic) so I had to get those replaced too.  I found some locally (I needed to get the bike togethor quick) for about double the cost of what I see them online, but racetech sells alluminum replacements.  If you are going to replace that spring or the plastic piston, please invest (Prior to starting this) with a thin 14mm wrench.  There is a brand "V8" that looks like it should work, or also a "Cone Wrench" by Park (SCW-14) that should work.  Also, if any of you do not kow what you are looking at, the part pictured on the far right is a valve stack; the shiny part on the left is the top of the fork that contains that bleed screw and compression adjustment.  You do not need to remove the bottom nut (can't see it in this picture); that is only done when you are revalving it / getting to the individual shims.  You just use that 14mm thin wrench on the portion right at the bottom of the plastic piston and the whole valve stack comes off in one piece.  At that point, the plastic piston slides off and you can change out the spring.
If the piston breaks, you may find it a pain to get your forks seperated because it builds up an extreme vacume in the dual chamber and the only thing keeping your forks from being in the bottomed out position is the main fork spring.  That bottom bolt cap you need to 1st unscrew to get your forks seperated will just spin (I thought mine was stripped at 1st).   Once you clear the threads, you need to push down on the lower fork leg like you would normally do, but this time you need to also pull in the opposite direction (I used channel locks) on the bottom of the inner fork (the bolt / cap you just turned with the ratchet / socket).
Edited by mch, May 22, 2014 - 01:37 PM.
  • sathio
Posted May 23, 2014 - 12:10 AM
thank you guys, I'll look into it.
see ya
  • MidlifeCrisisGuy
Posted July 19, 2014 - 05:08 PM
Do these springs do anything other than prevent cavitation ?   Do they affect plushness in any way ?
  • cubera
Posted July 19, 2014 - 08:07 PM
Forks: .48-.50 kg
Shock: 5.7 kg
I'm about your weight and run .52/6.3 and it is perfect for open desert. These rates are the ones recommended by my suspension guru ASRacing. It's like cheating
  • mch
Posted July 20, 2014 - 05:12 AM
I have always liked mine a little softer, but can imagine where a little stiffer rate would be nice at times.  I'm guessing a lot of people who have never rode desert think it's smooth riding... but desert whoops can be insane.. and they don't seem to end anytime soon.
  • mch
Posted July 21, 2014 - 06:21 PM
Honestly, I'm not sure what the difference was, as I changed both springs at the same time.
  • cubera
Posted July 22, 2014 - 02:17 PM
No doubt we joke about the "death whoops" in District 38 racing. A properly suspended machine will allow even an old fat guy like myself to become proficient on the whoops but still it's not a good idea to become overly confident. :banghead:  :lol:  :foul:  :ride:
  • RockerYZWR
Posted July 22, 2014 - 02:34 PM
And how. I want to say I hate the whoops but I don't. I just wish I was faster and didn't get so exhausted going through them. I need a revalve.
  • cubera
Posted July 22, 2014 - 05:28 PM
Call 661-993-0466 and ask for Kelley (she'll probably answer) and tell her what you need. You'll get hooked up with the best in the business.
