Mineral spirits too clean air filter
10 replies to this topic
  • Mtrain730
Posted May 21, 2014 - 11:42 AM
So just cleaned my filter for the first time after switching too bel ray filter oil. I put the filter in a plastic container poured a couple inches of mineral spirits in put the top on shook the container around a little let it set for 5 minutes squeezed most of the mineral spirits out but didn't go crazy because i washed it in soap in water after and figured that would wash the rest out. The filter came out real clean. Is this a ok way too do it. There was a little blue tinge of filter oil on the out side edge around were the cage presses on the filter(2012 with flat filter) is that ok. I tend too over think stuff other then a little bluish tint what I assume too be a very small amount of filter oil left behind around the edge the filter is almost new looking. Thanks guys.
Edited by Mtrain730, May 21, 2014 - 11:44 AM.
Posted May 21, 2014 - 11:57 AM
It's fine, but don't shake the container.  Fill it with at least a half gallon of MS and use the same stuff over and over.  Wet it squeeze it out, repeat until satisfied.   When the stuff gets too dirty to use, drain it off and scrape the accumulated dirt off the bottom.
As long as you re-oil the filter thoroughly, all the way through the foam (work it in, don't just spray it on), it won't matter that the filter did not get to be medically clean, because anything that's left will simply be trapped there by the new oil
  • Mtrain730
Posted May 21, 2014 - 12:48 PM
Ok thanks gray. So I shouldn't shake it because I will be stirring the dirt up that's on the bottom I assume.
  • CZRoger
Posted May 21, 2014 - 01:08 PM
I too used MS for the first time this week via the Gray method. Happy with the results except it took two days for the filters to be fully dry.
  • Mtrain730
Posted May 21, 2014 - 01:17 PM
is the soap not necessary just a good rinse?
Posted May 21, 2014 - 01:39 PM
Neither the soap nor the rinse is necessary.  But the rinse is a waste of water unless soap is used.
  • dirtbeater
Posted May 21, 2014 - 04:57 PM
I like to put a few inches of water in the bucket. MS will float and dirt sinks "kinda" getting trapped in the water. Great method and cheap.
  • stevethe
Posted May 22, 2014 - 06:29 AM
Is there ever a need to get rid of the old mineral spirits and where ?
Posted May 22, 2014 - 06:55 AM
Yes, eventually it will get to the point where there is so much filter oil dissolved in it that the filter elements will come out with an oily residue on them.  To an extent, this is actually OK, too, but at some point it gets to be too much.  Anyplace that does oil recycling will normally accept it, and mostly, such services are free.
  • Mtrain730
Posted May 22, 2014 - 07:32 PM
weird question gray so technically if you took a clean dry filter and dropped it on the ground and got it dirty or dusty (with in reason) on the inside and out side of the filter as long as you thoroughly oil the filter the dirt should not get sucked in to the engine. The oil has that much holding power. Not that you would purposely do this but even if you have dirt on the inside of the filter the oil should hold it in place. Sorry for the dumb question.
Edited by Mtrain730, May 23, 2014 - 06:44 AM.
Posted May 23, 2014 - 06:48 AM
It's not a dumb question, really.  The thing about foam element filters that makes them different from the fiber mat filters ("paper") in your cars is that they have no ability to stop anything at all that is smaller than the pores in the foam from passing straight through them unless they are oiled.  It is only the oil that traps and holds the finer stuff, and in operation, the oil and dirt come together only when the dirt strikes an oily strand of foam as it tries to wiggle through the foam.  If that will hold it, pouring oil over the dirt in an otherwise dry foam filter certainly should keep it from going any place.
As you say, that practice you describe would hardly be advisable, but neither does it make sense to concern yourself that there might be a tiny amount of dirt left in a filter before you oil it.
  • Hot  28 replies
  • Hot  47 replies
  • 10 replies
