2013 review
9 replies to this topic
  • bradgross71
Posted May 18, 2014 - 03:38 PM
So I have about 15 hrs on my bike and thought I would give my opinion. First off what I have done is fmf slip on, comp ecu, dunlop mx 31 for front and have set my co to ten. My map is all +3 on the fuel side and all +1 on ignition side. This bike is awesome!! I ride in michigan (sand whoops and twisty) and put the bike in third gear and can pretty much leave without using clutch. No matter how low the rpm drops in third I can roll the throttle and it just pulls your arms off. Whoops full throttle in third or fourth and tracks straight. I have had kdx 250, cr250, ktm300 xr 400 and this bike is far better than all of them. I would recommend trying the above map, is seems fuel delivery is about perfect. If your having trouble starting your bike after you fall or stall I recommend this. Hold full throttle and turn over for 2 or 3 seconds and then let off throttle then hit starter again. Mine fires every time.
  • Navaho6
Posted May 19, 2014 - 06:46 AM
Reset the CO level to 10 with the Yamaha FI diagnostic tool and it will start easier.
  • bradgross71
Posted May 19, 2014 - 08:14 AM
That's where it's set at
  • 5270ADVRIDER
Posted May 21, 2014 - 04:24 PM
Michigan rider here too with the same WR. Love this bike more and more every time I ride!
  • worstell
Posted May 21, 2014 - 06:51 PM
I'm close to pulling the trigger on a leftover 2012 WR450F.  But I am hesitating because I am afraid it will be to much weight and power for the super super tight technical stuff.  I currently ride a XR400R which I manage just fine in those conditions.  How will the WR450F compare?  I think they are about the same weight.
  • Navaho6
Posted May 21, 2014 - 07:30 PM
Power can be tamed with the tuner.  The bike is a little heavy but it hasn't been annoying for me.  The suspension does a good job and it turns really good without being twitchy.  If all you ride is super tight trails, it will overheat if you don't change the mapping and ditch the oem exhaust.  I've done this and changed the CO level to 3% and it had never boiled.
Edited by Navaho6, May 22, 2014 - 09:16 AM.
  • bradgross71
Posted May 22, 2014 - 03:18 AM
If you like your xr you will love this. I have had 2 xr400.
  • bradgross71
Posted May 22, 2014 - 03:21 AM
My mso said the bike was 261 pounds. I think a 450 ktm xcw is 254. That's not a big dif.
  • 080
Posted May 22, 2014 - 07:06 AM
The Wr won't be much of an improvement over the Xr in just the tight stuff. The benefit of having the Wr would be once the pace is picked up.
  • worstell
Posted May 22, 2014 - 04:19 PM
Navaho6, which map should I run to avoid overheating.  I was thinking to run the woods map.
