Fuel / Octane
6 replies to this topic
  • bobpara
Posted May 14, 2014 - 11:53 AM
I just read the factory manual (I have an '06 WR450)
They call for 95 octane
Here in Mass, I have been using 93 octane.
93 RON is pretty much the standard here w/ the exception of 94 at Sunoco
I have also been noticing a slight knocking coming from my engine
Anyone have any experience with octane & knocking on one of these?
  • Krannie McKranface
Posted May 14, 2014 - 12:43 PM
I doubt you are experiencing detonation with a stock motor. The compression is not high enough to get detonation, unless you are very lean.
If you are stock (corked, mapping) you need to uncork and re map anyway because they come way too lean.
Use the highest octane pump gas available to you.
Edited by TheKoolAidMadeMeSick, May 14, 2014 - 12:48 PM.
  • bobpara
Posted May 14, 2014 - 01:02 PM
I'm stock on the air cleaner and pipe ('06 WR450)
I'm pretty sure the stock spark arrestor is in there too
The bike ran really good when I got it so I found no pressing need to re-jet (It has a carb and not FI)
The bike was pretty clean and stock when I got it
So I'd bet even the stock jets are in there
From experience alot of bike come from the factory way too lean
Any suggestions , or any link to,  jets?? (I live in Boston at sea level)
So the bottom line on all this is that I could be very well running lean.
Posted May 14, 2014 - 01:59 PM
Look at the FAQ post and Jetting posts at the top
If you are running stock jetting and exhaust, you are FRYING your stator......it's just too lean and runs too hot.
  • bradgross71
Posted May 14, 2014 - 02:21 PM
You sure u are reading North America info? Octane rating vary in other country's. Sounds like a Australia rating to me
  • bobpara
Posted May 15, 2014 - 05:23 AM
No, octane rating is directly from factory manual for the '06  page 1-21
I am looking at the stock jetting vs what others are running and I'm seeing very little difference (I have carb not FI)
So I cant understand why it can be said that its running lean and will be too hot, fry, etc
Posted May 15, 2014 - 04:10 PM
All off road bikes (non track) are shipped EXTREMELY lean to be way inside the Epa limits.
This makes the bike run poorly and run very hot.
You need to do more reading in the FAQ section as most of this stuff and your other 5 posts are covered there.
