2002 WR426F Wont Start
4 replies to this topic
  • WR426Fanatic
Posted May 14, 2014 - 04:15 AM
I hope this the correct section, I have a 2002 wr426f dirtbike (my first bike ever, havent even got the chance to ride it yet even though my father has twice) which after 3 hours of trying to kickstart just wont freaking start. We hear pops every once in a while, while we are using the red hot start button. We took the bike apart and checked to see if there any noticeable problems with the spark plug or anything else. We noticed that the plug that insulates the line going to the spark plug, had sustained damage and we use super glue and electrical tape to help stop that problem in case it was a contributing factor. Also the night before I accident left the fuel switch to On. So as im sure you can guess there was a gasoline leak all night for about 14-18 hours in my shed, thank god no sparks happened. But that lead me and my father (the latter is the mechanical genius of us two.) To think it had something to do with the Float. Any suggestions on what the issue might pertain to?
  • Gordo DeDog
Posted May 16, 2014 - 07:10 PM
I've got the same bike put the hot cam in it , you'll love it much easier to start
Sounds like you are flooding it. I would like to say they are easy starters but they aren't. Once you learn how she wants to be started 1st to 2nd kick
  • Krannie McKranface
Posted May 16, 2014 - 08:21 PM
Service the carb, top to bottom
http://www.dirtrider...r_carb_rebuild/
Adjust the valves for correct clearance
Replace any damaged high tension leads
Clean the harness connections
Clear the stator of any stray ferrous metal particles
No point in just kicking it for three hours.
It's either going to start in a few kicks, or it's not.
  • WR426Fanatic
Posted May 17, 2014 - 04:23 AM
thanks
  • manotickmike
Posted May 17, 2014 - 05:04 AM
I still don't know how to link from this tablet, but like the koolaid says get to know your carb. Yamaha site, bikebandit, rocky mountain all have diagrams. Tear it down get everything surgically clean. I'd get all new jets, and a needle and seat valve. Make SURE the fuel shut off on the tank works. Replace that too, if it leaks.
I just got the same bike, and while the previous owner managed to start it, there was NO WAY it was going to go a month later when I got it home. Now I know what makes the carb tick, and what state everything is in.
Priceless.
