2012 WR450f rear brake light conversion... help
Yamaha WR450F
14 replies to this topic
  • StandardFish450
Posted May 11, 2014 - 10:49 AM
Hey everybody! This is my first time here. So i recently bought a 2012 WR450. I got the dealer to hook me up with a street legal title and reg. My issue is that when I first bought the bike, the previous owner had taken off the headlight, instrument cluster, and taillight, and replaced them with YZ parts. I'm wondering what it would take to convert the tail light to a brake light so I can ride the bike on the street. (Not that I don't anyway, but at 17 I don't need my insurance hassling me any more. <_< ) I've seen a few different threads about people doing this, but I cant make sense of what I need to do or what wires I need to splice into. If someone could help that would be great. Thanks and happy riding!
So in this picture I noticed that there are 3 wires on the plug of the actual taillight but only 2 on the plug on the bike. I assume this blank is the switch wire? I just don't know where to start right now.
Edited by StandardFish450, May 11, 2014 - 10:52 AM.
  • bradgross71
Posted May 11, 2014 - 02:34 PM
Get a hydraulic switch and hook one wire to battery (doesn't matter what one) and hook the other to the black hole in your pic. Done deal
Sorry, blank hole
  • funt
Posted May 11, 2014 - 03:16 PM
I can't remember if the stock taillight is hooked to the bright setting or the dim one.  I hooked my switches to one of the brown wires I think for switched power.
Edited by funt, May 11, 2014 - 03:26 PM.
  • StandardFish450
Posted May 11, 2014 - 06:12 PM
Ok thanks a lot guys! I found a few options on ebay for less than 10$. I just need to find a thread match for the banjo bolt. Anyone know off the top of their head what size the threads are for the '12 WR450 front master cylinder banjo bolt? 10x1.25 or 1mm?
Edited by StandardFish450, May 11, 2014 - 06:12 PM.
  • flyandride
Posted May 11, 2014 - 07:24 PM
It's the 10 x 1.25 that you want.   10 x 1.0 is for euro bikes.  The stock WR tail light has a brake light in it.  You just need to hook up the switch.  3 wires go to the tail light, black is negative, blue is for tail light, white is for brake light.  WRs come with the tail light hooked up.
  • StandardFish450
Posted May 12, 2014 - 05:22 AM
Cool thank you. Maybe dual sporting this thing is closer then i thought. :thumbsup:
  • bobpara
Posted May 12, 2014 - 05:41 AM
If you live in a 'strict' state like I do, you need front & rear brake light, blinkers, hi/lo headlight, kickstand, a key switch.....the whole 9 yards
You travel 20 miles from my house and go to New Hampshire ans all you need is a red light on the back, no brake light.....very lenient
I am a big fan of having a road legal dirtbike, and it seems you are too
If you ever get caught in, should we say a compromised situation, of where you should be riding
a cop or an EPO has a lot less to work with as far as charging you with various things
All that said, me and many of my friends have been this route before
Go to the one and only place, Baja Designs
1) Right equipment, 2) Replacement parts if you break them 3) Support in installing
http://www.bajadesig...emNumber=121230
  • funt
Posted May 12, 2014 - 05:54 AM
Tusk has a reasonably priced kit, I think.  I pieced together my stuff from ebay mostly.  My wiring job isn't the cleanest though.
Edited by funt, May 12, 2014 - 05:55 AM.
  • DuncR6
Posted May 12, 2014 - 06:03 AM
Yes the blank is for the switched brake light...
Black wire = grouf
Blue wire = 12v+ running light
Yellow wire = 12v+ switch brake light
You can get the OEM connector pins and rubber dust seals to do your wiring the right way from K&L Supply.  I think they are on page 119ish of the current downloadable catalog.
Edited by DuncR6, May 12, 2014 - 07:33 AM.
  • bobpara
Posted May 12, 2014 - 06:07 AM
I'm not trying to bust 'em on anyone, but if you go with piece-mealing things off of ebay it will eventually come back to haunt you.
If you bust a particular part, you will most likely have to do some craft work to get another dis-similar part to work
(99% of time that Chinese supplier is gone in a year or two)
If you cant find the same rear tail light, and if you don't mind swiss-cheezing your rear fender with 2 or 4 more holes....all the power to you
If the part has a different pin-out and you don't mind getting an ohm meter and screwing around with it for a couple more hours
Or, if you buy a POS handlebar switch or hydraulic pressure switch that breaks annually and don't mind replacing it, fine
I buy all my hardware from Baja Designs.
They have been around for a long time and are unlikely to go anywhere
The support is second to none
One stop shopping
Note: I do not work for these guys or even have a friend that does or anything, ....but I like them that much.
  • StandardFish450
Posted May 12, 2014 - 02:44 PM
Yeah i really like the idea of a kit, but unfortunately, I cant afford one of those things, not to mention i'd have to do a lot to take all the stuff back off to use it as a dirtbike. I do a lot of pounding whoops in the desert, so any extra weight and fragile plastic stuff would be the death of me. This isn't going to be a permanent supermoto project. That's why I'm just going to stick to modding stock parts to work "good enough" and having nothing extra. And as far as I know, I can get away with no turn signals or hi/low beam or anything in my state, so that's what ill have to do.
  • DuncR6
Posted May 12, 2014 - 06:21 PM
If you want a light, easy to replace if broken, proven setup then do this:
1.) Buy a TRX450R front master cylinder.  This uses an electrical switch to activate the brake light that is part of the master cylinder.  The master will bolt up to the stock handlebar on the '12 WR450.
2.) You can use the 12v+ wire that powers the useless little 3w light bulb underneath the main headlight bulb.
3.) Then run a single 12v+ wire back to the connector you had shown in your original post that is next to the ECU.  Put it on the pin with the yellow wire that goes to the brake light.
4.) Now you have a permanent brake light setup using all OEM parts.
  • duggram
Posted May 14, 2014 - 01:19 PM
OP:  Are you close to ABQ?   I just put the BD kit on my 2012WR.  Very Slick.  You can have the brake line banjo I was using before.  The kit is nice because it has those things you need to be legal.   Like hi/lo headlight.
  • funt
Posted May 14, 2014 - 02:16 PM
Used stuff is nice too because you get push button cancelling on the turn signals and the connectors are OEM quality.
  • StandardFish450
Posted May 15, 2014 - 05:26 PM
Yea im out on the other side of the mountains. And Thanks a lot but I already have one on order. It's a little chinese POS though so if it breaks or some shit I might have to take you up on that  :thinking:
05 wr450 oil leaking from fuel tank mounting hole by gee-tee
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • 0 replies
Valve Cover gasket keeps blowing by pbcrazy9898
  • Hot  29 replies
Show Us You 2016 WR450f & Mods by chelder
  • Hot  34 replies
Should i switch to a ktm 300 exc or xcw from a 2009 wr 450f by Tattoojunk
  • Hot  76 replies
Just curious how much i could get for my bike not intrested in selling though by mikerussell97
  • Hot  35 replies
