Need help fast! Oil change 14 yz450f
13 replies to this topic
  • ttr230rider6
Posted May 11, 2014 - 04:29 AM
I have 10 hours on my bike, and I have changed the oil twice. Once at 1 hour with a new filter and again at 5. I am now needing to change it again along with a new filter. Each time I did it so far with the filter replaced or not I put in 0.69 L and it was above the low mark and no oil came out wil hitch is good according to the manual. But there is one thing I don't get in the manual. Here's a pic of it. I assume it means 0.69 L for when you just change oil and if you change the oil and filter. But what does it mean when it says quantity (disassembled)? Does it mean if you took the cases apart and it was completely dry or what? ImageUploadedByThumper Talk1399811321.832982.jpg
  • crf917rider
Posted May 11, 2014 - 04:39 AM
.95 is if u change oil filter also
  • ttr230rider6
Posted May 11, 2014 - 05:10 AM
But why does it say quantity with oil filter element replacement 0.69L ?
  • DC_Excitement
Posted May 11, 2014 - 05:15 AM
yes disassembled means if you took the engine apart, all the oil cant come out by simply draining it, there are channels that the oil can get trapped.
  • crf917rider
Posted May 11, 2014 - 06:45 AM
The way i read it .69 was without filter change
  • slammedmind
Posted May 11, 2014 - 06:49 AM
if you replace the element (filter) and the oil then 690ml. If you tear down the bike and rebuild it then its 0.95l.
  • ttr230rider6
Posted May 11, 2014 - 04:58 PM
Alright thanks man. I know that for sure now because earlier I put 0.95 in it and opened the check bolt and a bunch came out. So I know it is 0.69. What about just changing the oil and not the filter? Still put 0.69 in?
  • DanielMerrick
Posted May 19, 2014 - 05:15 PM
Just put .69 in and level the bike and take the oil check bolt out till all the excess oil is drained.. That's what I've been doing, acording to the Manuel it need to be higher then the "low" on the glass and lower then the check bolt!
  • Gaz929
Posted May 21, 2014 - 09:54 AM
I change the oil and filter after every ride and always put 1L of oil back in.
  • drtrcr400
Posted May 21, 2014 - 10:12 AM
Congratulations on over filling your engine.
  • Gaz929
Posted May 21, 2014 - 10:16 AM
I've never had a problem yet with all 5 oil changes!
Edited by cr250fletch, May 21, 2014 - 10:16 AM.
  • Gaz929
Posted May 21, 2014 - 10:20 AM
Where is the oil check bolt? You have me worried now :(
  • ttr230rider6
Posted May 21, 2014 - 05:01 PM
It shows you exactly where it is in your manual haha. You said it hasn't hurt in the last 5 oil changes. You won't notice a difference in 5 oil changes especially if changed after each ride. But it will definitely have long term effects.
  • swaldrop
Posted May 21, 2014 - 05:18 PM
1L of oil is way too much for the '14. Would have worked great in a '13 though.
  • Hot  30 replies
  • Hot  113 replies
  • Hot  47 replies
  • 0 replies
