Desert tank and radiator guards on an 05
10 replies to this topic
  • 06gixxer1k
Posted May 10, 2014 - 11:04 AM
I have an 05 wr450 with unabiker radiator guards. I just bought a used acerbis 3.3 gallon tank and it will not line up without removing or modifying my frame guards. Does anyone have any idea which desert tank would work on my bike with these radiator guards?
  • Krannie McKranface
Posted May 10, 2014 - 11:51 AM
No tank, without modifying the guards.
You should get rid of those unibikers anyway, and get Mohard or Moose cage guards.
  • 06gixxer1k
Posted May 10, 2014 - 12:25 PM
So did you cut a notch into your guards?
  • 06gixxer1k
Posted May 10, 2014 - 12:27 PM
I actually bought these after seeing them installed on your wr. If I'm not mistaken I looked up the mohards and they only had them listed for 07+
Posted May 10, 2014 - 03:50 PM
Mine are all hacked up.
Now I have oversize radiators, and they will probably have to go
  • 06gixxer1k
Posted May 10, 2014 - 04:12 PM
Ok thanks. I'll take another look and modify it as needed.
  • 06gixxer1k
Posted May 12, 2014 - 06:29 AM
So did you cut a notch into your guards or what approach did you take?
Posted May 12, 2014 - 06:44 AM
I don't remember, and they are apart in pieces right now..........
  • condor74
Posted May 13, 2014 - 07:12 PM
If you are wind up not using the tank, I would be interested in purchasing it from you.
  • 06gixxer1k
Posted May 15, 2014 - 03:35 PM
:thumbsup:  I haven't gotten around to trying to make it fit but I'll keep you in mind.
  • still2smokin
Posted May 15, 2014 - 09:02 PM
I have been using the Devol guards , didn't like them at first but so far it works ok .
No major get offs yet but I have laid it down at least ten times and they haven't moved............yet .
