2012 + Front Disc Covers?
4 replies to this topic
  • Alstar450
Posted May 07, 2014 - 06:01 PM
Hey guys.. So I'm looking to put a front disc cover on my 2012 WR450 and haven't been able to find anything but the Acebis Spider Evo with the metal bracket. I'm already looking for ways to shave weight so the idea of a metal mount isn't appealing to me. The Lightspeed carbon fiber one from GYTR says ot works for both 08+ YZ450's and the 12+ WR, but no one else's can confirm that when cross referencing model #'s. I also have a 07 YZ450 and I know the 08+ disc covers are different. Do any of you guys run an all plastic cover, or know which one will fit? I like the Cycra version and am about to just order the one for 08+ YZ's and hope for the best. Thanks
  • Krannie McKranface
Posted May 07, 2014 - 06:37 PM
A full cover system can cause your brake fluid to over heat and your pads to burn up, unless you ride mostly flat terrain.
The Carbon fiber cover will disintegrate in one fall/rock as well.
It's aluminum or nothing.
The '08 YZ can be made to fit, as they use them in AU all the time for mud.
  • vlxjim
Posted May 07, 2014 - 08:23 PM
I have the Acebis X-Brake and its not as bad as you think. It replaces the stock spacer. so your just adding the little flat plate with threadserts. It fits great.
  • Alstar450
Posted May 07, 2014 - 08:48 PM
Thanks Kool aid. I've always run them and have had zero issues... I run big brake kits too and don't want even the stock rotors to take a beating.
  • Alstar450
Posted May 07, 2014 - 08:50 PM
oh ok, that's good to know. I will run one in lieu of going without it, but if The Cycra or similar works then I'll do that. Thanks for the info though
