Question about bleeding rear break, and oil question 06 yz450f
7 replies to this topic
  • hod928
Posted May 01, 2014 - 01:41 PM
Hi everyone, i just picked up a 06 yz450f last week and all week i been having some new stuff coming in (tires, bars, etc. While i had the bike apart i look it down to clean it really good and took the brake line off the rear caliper. Well i was not thinking when i went to put the swing arm bolt back in and pushed down on the rear break foot lever.
I have tried and tried to bleed the air out of the brakes. I have also filled the reservoir back up to make sure its not empty.While i have the bleeder screw open im pumping the foot lever but no fluid is coming out. Any ideas on why i cant get no fluid to come out?
And for my second question what do people recommend for oil Full synthetic? semi? Conventional? what brand?
Thanks!
  • bradgross71
Posted May 01, 2014 - 05:21 PM
Had same problem. Pump up pedal and instead of bleeding at the rear bleeder do it on the banjo bolt on the master cylinder. I
  • hod928
Posted May 01, 2014 - 09:23 PM
The reservoir is the master cylinder right?
  • SAthump
Posted May 01, 2014 - 09:40 PM
Pull the caliper off (keep something between the pads)
Unloop the hose
Raise the caliper so the bleed screw is truly the highest point
Then proceed with normal bleeding process
If you have friends it will be easier
  • bradgross71
Posted May 02, 2014 - 04:47 AM
Trust me, banjo bolt!!
  • seacraft69
Posted May 02, 2014 - 07:02 AM
Go to harbour freight and get yourself a vacuum bleeder. Cost around $20 for a decent one and will save you time and aggregation.
  • bradgross71
Posted May 03, 2014 - 03:13 PM
Did ya get it?
  • hod928
Posted May 03, 2014 - 06:44 PM
Did ya get it?
Yes and no, My yzf master come to find out has a very small crack in the master cylinder cap allowing air in (weird how it just started affecting it after i allowed air in..but anyways) we were able to mount a old 90's honda master cylinder on no problem and it worked just fine so im running that until my new cap gets in.
  • Hot  38 replies
  • Hot  30 replies
  • On January 15, 2017
  • 3 replies
