Clutch arm spring help
Yamaha YZ426F Engine Clutch & Components
2 replies to this topic
  • rustynail
Posted May 01, 2014 - 04:43 AM
I have a YZ426f 2002 I removed my clutch arm to make it longer because the clutch was really stiff. Any how when I removed it I saw the return spring was like in pic 1. Pic 2 is the way I think it should go. What do guys think? Should the spring be in the notch or on the other side.
ImageUploadedByThumper Talk1398948114.915035.jpg ImageUploadedByThumper Talk1398948132.799860.jpg
Posted May 01, 2014 - 04:55 AM
Set it so that as the arm is pulled the spring compresses .
Posted May 01, 2014 - 06:06 AM
The spring should pull against the cable to return the lever to its normal at rest position.
