2012 WR450 Low Fuel Light Problem
6 replies to this topic
  • mc1hd
Posted April 29, 2014 - 07:17 AM
After removing the headlight,computer and relocating the ignition button the low fuel light stays on full time.  Have been riding this way for some time and not experienced a problem other than not knowing how much fuel is left.  Looking at the wiring diagram not sure what could be done to fix the problem.  Maybe a resistor or a jumper but not smart enough to know how to go about it.  I know a clear tank would solve the problem (I have a ims but prefer the stock tank feel).  Help much appreciated.
  • funt
Posted April 29, 2014 - 08:59 AM
It sounds like a bad sender to me.  Or there is a short to ground on the sender wire or the wire going from the ECU to the ignition button.  I removed my computer.  Didn't remove the headlight but I don't think that would matter.  I think if there's a short to ground, the light will stay lit if you unplug the sender.  If it goes out, the sender is probably faulty.
Edited by funt, April 29, 2014 - 10:04 AM.
  • mc1hd
Posted April 29, 2014 - 03:49 PM
Seems like I am not the only person that has experienced this problem, another member Corkster had same issue.  After he re-installed the computer and engine fault light everything went back to normal.  So if I understand what you are saying funt I should try unpluging the fuel sender while ignition is on and if it stays lit I should have a short somewhere.  I would think the fuel sender is operating correctly since the bike starts and runs perfect, will try what you described and also reinstall the engine fault light and see what happens.
Edited by mc1hd, April 29, 2014 - 03:55 PM.
  • mc1hd
Posted April 30, 2014 - 09:49 AM
Problem solved, should have gone with my first thought of it being resistor related.  There is a ceramic 10w 68ohm resistor mounted to the odometer bracket on the left hand side of the cluster, one wire goes to to the main switch and the other back to ground.  Once pluged back in fuel light operates normally.
  • funt
Posted April 30, 2014 - 10:13 AM
Cool. I still have the bracket on mine.  That's good info, maybe I should take the bracket off.
  • mc1hd
Posted April 30, 2014 - 11:06 AM
Main reason for removing the headlight and odo for me as I do not use them, installed a yz number plate and put the other parts in a box for when I sell it.
  • Corkster
Posted April 30, 2014 - 02:43 PM
Great find - thanks for this one!
