Transmission rebuild? $
9 replies to this topic
  • bmxchamp00
Posted April 28, 2014 - 07:53 PM
So my yz426 has a problem with 5th gear; every other gear is perfect except the 5th one which slips back and forth from 5 to 4. I know it is transmission, and I really want to get this fixed. Can anyone give me an estimate of how much this would be to bring into a shop to get rebuilt/fixed?
  • adam8781
Posted April 28, 2014 - 08:56 PM
more than the bike is worth. if you could bring just the bottom end to the shop it might be more cost effective.
Get a manual and rebuild it yourself.
  • 1987CR250R
Posted April 28, 2014 - 09:41 PM
Just replace what is bad.  It costs about $25-35 per gear wheel.  Each speed has two gears associated with it.  You really need to go in for a visual inspection.  Transmission problems usually cost between $65-350 in parts unless you munch it really badly and you can do your own labor.  Don't forget to inspect the shift forks and shift drum.
Edited by 1987CR250R, April 28, 2014 - 09:42 PM.
  • wolverine_05_
Posted April 29, 2014 - 03:16 AM
I'm currently trying to repair my crf250r that has a weird tranny problem and when I called all of my local shops, it would have cost me over $400 in labor if I took the engine off myself and only brought them the bottom end. If you're mechanically inclined and have some extra time, I say do it yourself.
  • bmxchamp00
Posted April 29, 2014 - 05:43 AM
So if it is only 5th gear then would I need a whole rebuild?
  • wolverine_05_
Posted April 29, 2014 - 05:50 AM
Not necessarily, but it's still gonna cost a crap ton. You don't actually know what's going on in your transmission and what needs replaced until you get in there and see what's up. You could have a broke shifting fork or a messed up gear or anything. I thought I had my problem solved until I actually saw the inside of it and now we can't figure anything out.
Posted April 29, 2014 - 06:46 AM
The typical "pops out of 5th" problem with a YZ426 involves replacing the 3rd and 5th gear on the main shaft, along with the #2 shift fork that controls the 3rd gear.  Third gear slides back and forth on the main shaft on splines, and is used to lock the free wheeling 4th and 5th gears to the shaft to engage them.  The locking lugs wear until they won't hold under a load any more.
Not really very expensive unless there is a lot of other stuff worn in there.  What adds up is all the gaskets and what not, and rings and bearings, if you decide to replace them.
  • wolverine_05_
Posted April 30, 2014 - 01:57 PM
That's what I meant when I said expensive. It's not the actual cost of the small things to fix it but all the hidden fees in between.
  • amamx19
Posted April 30, 2014 - 06:59 PM
I'm in the process of tearing my 426 trans apart because it drops out of 5th under power. So far it looks like I need:
2- shift forks $55/each
probably the drum $100
gasket kit $168
already replaced I believe 2nd and 3rd gear which was $30 and $50 when my uncle was working on it. Along with some main bearings and the center shift fork $55.
So even tho I'm doing it myself it is still getting expensive quick! I was told about $800 in labor if the shop did it, even with motor already out of the bike.
  • Jdrost72
Posted April 30, 2014 - 09:19 PM
U might be able to find a motor with a good bottom end.
  • Hot  38 replies
  • 10 replies
  • 0 replies
