2001 yz 426f
12 replies to this topic
  • B_Powell07
Posted April 21, 2014 - 11:31 AM
I need some help or ideas.
On deceleration my 01 yz 426f popping like crazy not sure whats up any ideas would be great
Posted April 21, 2014 - 12:19 PM
http://www.thumperta...t/#entry2983539
  • B_Powell07
Posted April 21, 2014 - 06:51 PM
Its not letting me click on the link grayraser513
  • B_Powell07
Posted April 21, 2014 - 06:54 PM
Another thing I noticed when the choke is out it runs fine no popping at all but as soon as I push the choke in it starts popping during deceleration
  • seacraft69
Posted April 22, 2014 - 07:13 AM
That link will probably be telling you your lean.
Posted April 22, 2014 - 08:09 AM
Not exactly.
Anyone else having a problem with  that link?  I'm not.
Here's what the post says:
Excessive decel popping is almost always the result of one or both of two things; lean idle mixture or an air leak in the exhaust. In some engines it can be brought on by a very excessively rich condition, but this is much less common. You should usually troubleshoot it by looking for the exhaust air leak first, because otherwise, you will end up with a bike that's too rich to run right because you fattened it up to cover over a pop that was actually caused by something else. Aftermarket pipes have a slip fit midpipe/header. Check it.
Lean idle jetting can be as simple as a fuel screw adjustment, or it can be an undersized or clogged pilot jet. Another, less common cause is a hot start plunger stuck partly open.
Besides, a little bit of popping on decel is normal for a YZ450, and IMO, any YZ450 that never pops at all is too rich on the pilot.
The '06 is, as was pointed out, built lean. I run a 45 pj/165 main, and it's worked well so far. When the bike first came out, in the cold months, a lot of guys immediately went with a 48/170 set up, and many of them dropped down to the 45/165 as the weather warmed up.
  • seacraft69
Posted April 22, 2014 - 08:45 AM
About the links, in the common threads section only some of them work for me. But I use my phone for innerwebs so I put it down to that. Also good to know about the 06 since thats what I have.
Posted April 22, 2014 - 09:03 AM
Don't have to use your phone...
  • B_Powell07
Posted April 22, 2014 - 10:05 AM
Thanks grayraser513. . I have zero air leak on the exhaust I checked the boot on the carburetor side and air box and its fine no dry rot. I'm starting to lean towards the jetting now because when the choke is on 0 popping when you ride but as soon as the chokes of it dies
Posted April 22, 2014 - 10:18 AM
Then the problem is the pilot jet either clogged, too small (not likely since it used to be OK), adjusted wrong, or the screw or O-ring is missing or damaged.
  • 72degrees
Posted April 22, 2014 - 12:35 PM
Our very poppy 04 450 is much less poppy (thought not completely) now with an o-ring that had gone missing replaced with along with a new after-market knurled adjuster. Easier to start too.
Posted April 22, 2014 - 01:30 PM
It's not supposed to be completely free of it.  They'll crackle on decel if everything is set as it should be.
  • 72degrees
Posted April 22, 2014 - 01:39 PM
It still does a little when running back down the hill on a closed throttle or under hard braking for a hairpin, but not as much as it did. I might have gone a tad too rich by adjusting by ear on idle speed though. At least it's easily tweaked now and it is certainly going well.
http://youtu.be/UifsUe5fZec
  • Hot  50 replies
  • 0 replies
  • Hot  47 replies
