Clutch in w/gas, bike stalls?
9 replies to this topic
  • SteveKing84
Posted April 20, 2014 - 03:10 PM
So I pulled my dirt bike out from winter storage (my garage) today, and after a dozen kicks it started up.  I would idle and rev just fine, however... when I pull in the clutch and try to rev it, it stalls out.  I can pull in the clutch without reving it and it will continue to run at idle.  The bike is not in gear, and was running just fine when I put away for the winter (had 2 rides on a ultrasonically cleaned carb too).  Stored with gas stabilizer.  Any ideas out there?  This doesn't make sense to me.
  • WALKINGWOUNDED
Posted April 20, 2014 - 03:46 PM
I have you tried holding the rpm's up high, and slowly pull in the clutch to see if it slowly kills the engine, or all at once?
What year, make and model bike?
  • SteveKing84
Posted April 20, 2014 - 03:53 PM
I haven't tried that.  Will do tomorrow though.
So far I have just started it, choke on until warm and then choke off.  It will rev plenty fine in neutral no clutch.  I allow the RPMs to drop to idle, pull in clutch and rev and it dies.
This is an 04 yz450f.
  • WALKINGWOUNDED
Posted April 20, 2014 - 04:00 PM
I've never owned a Yamaha, but didn't some of their bikes have a switch located near the shifter, that would advance the timing when shifted into gear to idle it up some?
If you have that setup, not sure how it's all tied together though.
I would say to check your cable routing, as it may be flexing when you pull in the clutch, and pinch a wire and kill ignition spark; but I would think it would kill it at idle too.
Edited by WALKINGWOUNDED, April 20, 2014 - 04:06 PM.
  • WALKINGWOUNDED
Posted April 20, 2014 - 04:06 PM
On other thing to think about.  I've been in the Automotive industry forever.  I've had vehicles come in with some of the strangest problems.  Problems that initially you don't think about because your looking for a naturally occurring problem.  When you finally pin down the problem, it was RATS chewing on wiring.  :jawdrop:
  • SteveKing84
Posted April 20, 2014 - 04:09 PM
Definitly no rats.  Just seems odd.
Edited by SteveKing84, April 20, 2014 - 04:10 PM.
  • Monk
Posted April 20, 2014 - 04:10 PM
Nevermind
Edited by Monk, April 20, 2014 - 04:11 PM.
  • WALKINGWOUNDED
Posted April 20, 2014 - 04:13 PM
Nevermind
Oh no you don't.
Let's hear it! :naughty:
  • billygildark5007
Posted April 21, 2014 - 08:27 PM
Make a new topic reading "help gray" and the master will figure it out
  • SteveKing84
Posted April 24, 2014 - 04:58 AM
Sorry guys, no update yet.  Called out of town for work, getting back tonight.  Hopefully I can play around with it then.
