Another wr426 backfiring thread
6 replies to this topic
  • s3v3red
Posted April 17, 2014 - 10:39 PM
I've messed with the carb until there's no end. It has done this since I got it last year. Maybe I'm confused. Should I open the pilot screw more until it quits (if it quits)?
The bike has an aftermarket exhaust, no known leaks.
Going to double check the timing in the morning.
Will post a video tomorrow also for better reference.
  • Krannie McKranface
Posted April 18, 2014 - 04:49 AM
Backfiring? You mean through the carb?
...or do you mean deceleration popping out the exhaust?
It's an excess air issue
- service the hot start, choke, slide seal, carb body top seal, air boots, exhaust junctions and header crush washer
THEN adjust and tune the pilot circuit.
  • Maddog03
Posted April 18, 2014 - 06:45 AM
You will probably always get some backfire on deceleration, the nature of the beast. The type of pipe and condition will cause more or less. Not to be confused with backfire under load or backfire through the intake.
  • s3v3red
Posted April 18, 2014 - 09:26 AM
Is this why it is difficult to start sometimes also?
  • mediumdaddy
Posted April 18, 2014 - 09:40 AM
Mine backfired like a boss no matter what until i replaced the exhaust gasket on the head. Fixed it right up.
  • fastfoodfred
Posted April 18, 2014 - 10:09 AM
Just guessing, but it is hard to start warm, right? Most likely from making the pilot more rich, trying to stop the pop. A certain amount of snap, crackle, and pop is completely normal and can be a sign of a good running engine. It should not sound like gun fire.
Posted April 18, 2014 - 11:24 AM
Jetting is the key
Of course, any air leak, anywhere will negate your best jetting efforts.
The X is one of the best starting bikes out there.....if you maintain your carb and jet it properly.
