throttle cable frayed, cam stuff etc...
5 replies to this topic
  • MikeOK
Posted January 11, 2002 - 05:36 PM
I started tearing into my engine this evening and I found something interesting you guys might want to check on your bikes. When I took the cables off the carb I found the top cable frayed so badly it was only hanging by 2 strands. This could ruin a good race day if it gave way on the face of a jump. You can check it easily, just take the plastic cover off the side of your carb and look.
Also I noticed that my rotor has no timing mark. I noticed this when I first checked my valve tolerances way back but I use the opposing cam lobe method of checking my valves so it hasn't really been an issue until now. Seems like I remember some others finding this on their '00 models but maybe I'm dreaming. Any of you found this on your bikes?
  • MX974
Posted January 11, 2002 - 11:36 PM
Mike...I went through a couple cables before I realized that the cable bracket near the carb did not hold the cable in line with the groove in the CAM. The cable rubbed on the side of the groove. I bent the bracket to align the cable and did not have any more cable problems. I would check the alignment, those cables are not cheap!
  • MikeOK
Posted January 12, 2002 - 04:23 AM
mx- thanks I will check that. You are right I checked Rocky Mountain last night and the replacement cables were $28, anybody know of a cheaper place to get them?
  • PK
Posted January 12, 2002 - 10:19 PM
I'm on my third set of throttle cables, I wish I knew they were only $28 as I paid $35 from Yamaha. Better check the alignment on my bracket since I'm obviously not smart enough to shop around for a good price. Thanks for the tip...
  • Shawn_Mc
Posted January 14, 2002 - 12:26 PM
You guys might want to make sure the little jam nut is properly set in the bracket. The jam nut is supposed to sit with a corner in the slot. Not with the flat against the bracket. If the nuts sits flat against the bracket, the cable misaligns and youll end up with frayed cables. I asked the question here but no-one responded. I finally took the carb off and sighted the whole assmebly. I dont think anyone knows about the nut thing except the guy that designed the bracket! :)
  • factorymark343
Posted January 14, 2002 - 02:32 PM
zip ty makes a trick pully. I got one and no problem.
  • Hot  491 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • 5 replies
  • Hot  28 replies
