Triple clamp questions
4 replies to this topic
  • sjwr450
Posted January 16, 2004 - 08:02 AM
Looking for a triple clamp that can meet these requirements:
Rubber mounted bars
Option to run Scotts or GPR damper
Choose taller bar mounts (currently I have adapters and love the extra height)
Thanks
  • jim-in-so-ore
Posted January 16, 2004 - 10:01 AM
I don't know who has all of that, but what I want to know is "Where did you get the bar risers? :)
  • Indy_WR450
Posted January 16, 2004 - 04:59 PM
Scotts set up with the rubber mounted handle bars using BRP made upper triple clamp is the way to go. All you need is a spacer and longer rubber mount bolts to adjust you handle bars higher. The system already takes you a little higher than stock. Rubber mounted bars are a dream! They are a god send on long rides. Pro-Tapers also come with the kit and you can get the bend you want as well for higher rise. :)
  • sjwr450
Posted January 16, 2004 - 05:53 PM
Tag supplied the risers.
  • Dez113
Posted January 17, 2004 - 10:00 PM
I use applied triple clamp, with the GPR version 2, damper, (underbar mount) which is also a riser, it is awesome, but a little pricey, around $450-500 new plus bars.
