2003 WR450F Accelerator Pump Weak Stream.
6 replies to this topic
  • tcashion93
Posted April 12, 2014 - 12:24 PM
I've been thru all the steps/mods of the bog issue and still have a weak stream out of the AP nozzle... I've done the o-ring mod put in a new diaphram and cleaned all the jets etc. I noticed there is fuel coming out this hole when the AP pump is triggered I just need to know if that is some sort of overflow (or normal)?... I thought it might be why the stream is weak, losing pressure here? Thanks for the help I'm a nooby with this style of carb but am not mechanically challenged just bear with me. THANKS IN ADVANCE!
  • Krannie McKranface
Posted April 12, 2014 - 01:08 PM
You need to service the apump system
Clean the apump passages, and make sure the check ball-bearing is not stuck
       - better yet, upgrade to the 2008 crf450r version: there is a kit for this on crf'sonly.com
Diaphragm: must be pilable and have the short rivet
No corrosion anywhere
Leak jet: must have 50 or smaller to get a properly filled up cavity
Linkage spring: if it is stock, it will never squirt right. You need to wire it shut (mickey mouse version) or better yet replace the spring with a merge racing or tokyo mods spring.
You might also soak the brass nozzle in some solvent: I used a little cap over the nozzle and squirted PB blaster underneath. You can also try a piece of wire from a wound guitar string.
Posted April 12, 2014 - 01:10 PM
Looking at the picture again, you are showing squirt with the slide down.
That is not right.
I think you nozzle is clogged and it's having a hard time 'emptying' the apump reservoir.
  • tcashion93
Posted April 12, 2014 - 01:16 PM
I'm positive all the AP passages are clean and clear. I really cant afford to buy an upgrade. I have considered grinding down the long rivet on the diaphram but wanted to see why the fuel was coming from that specific hole, or (if that was normal)? I can troubleshoot from there.
  • tcashion93
Posted April 12, 2014 - 01:18 PM
Oh and as for the timing with the slide down. I dont have the throttle cable hooked up so I just manually pushed the AP lever and it is both a short and weak stream.
  • William1
Posted April 13, 2014 - 02:24 PM
Inspect/test the check valve in the float bowl.
You cannot fully operate the AP how you did. Rotate the throttle wheel quickly.
Posted April 13, 2014 - 07:49 PM
