Best 2012 throttle mod for jerky response?
9 replies to this topic
  • tomjoens
Posted April 09, 2014 - 07:31 AM
What do you guys think? Throttle body mod by injection engineering, 4.4 oz flywheel, or gytr tuner?
Edited by tomjoens, April 09, 2014 - 07:31 AM.
Posted April 09, 2014 - 08:37 AM
Of the three, the most effective to address that specific problem is the throttle body.
  • the go-devil
Posted April 09, 2014 - 09:59 AM
I run the 4.4 oz flywheel and a G2ergo Dirt Tamer throttle and with great results. I don't get fatigued as easily with the Dirt Tamer installed. It works really good.
  • atf8611
Posted April 09, 2014 - 06:04 PM
Injectioneering. I just had it done to my 2011. It's a night and day difference. The problem is in the throttle body. Anything else is just a band aid solution. It took care of 99% of the problem.
  • gofaster450
Posted April 10, 2014 - 02:31 AM
Agree with atf8611. Injectioneering mod made the biggest difference. This combined with a flywheel weight is pure bliss. The G2 throttle tamer only made a small difference and after the above changes, have replaced it with the factory throttle tube.
  • Gunner354
Posted April 10, 2014 - 08:41 PM
What exactly do they modify and how
  • atf8611
Posted April 11, 2014 - 03:17 AM
You can give the guy a call, he's more than willing to discuss the procedure. I don't remember exactly what the mod entails, but it certainly works.
Posted April 11, 2014 - 12:07 PM
As I recall, the thrust of it is that the angle of the throttle plate in the fully closed position is changed physically, with necessary associated tweaks done along with that.  This alters the rate at which any certain amount of rotation increases the size of the air path during the first 5% of opening.
  • galligar
Posted April 11, 2014 - 01:59 PM
1st thing I did on my 10,it works, you can play with maps, fly wheels,throttle tubes, the injectioneering mod is the cure,rode bikes with just the other mods not as good. It costs $200+ its the best fix.
  • FZ1426
Posted April 13, 2014 - 04:45 PM
GYTR Tuner "less hit" map. Done deal.
  • 5 replies
  • Hot  47 replies
  • 0 replies
