Backfiring, Ignition Governer, Jetting
1 reply to this topic
  • salz
Posted January 15, 2004 - 03:53 PM
At the higher altitudes (7,500 feet and up) my '02 WR426 backfires quite a bit - any suggestions - see jetting & mods in my signature below.
Also, the WR starts fine, idles fine, runs really good from 0 throttle to 3/4 throttle. Problem is if I am at a
standstill in first gear (or going slow in 2nd or 3rd) and hold the throttle wide open for a few seconds at
the higher revs it is "cutting out" or "mis-firing" (sort of difficult to describe).....could this be the
jetting set up, or could it be the timing, or could it be the governer kicking in (some have said it is just
the governer doing it's job- I'm not sure).
Any advice would be appreciated..... :)
  • dominator426
Posted January 16, 2004 - 01:56 AM
Sounds like you're a bit lean on the main fuel jet. Did it worsen in colder outside temperatures? What type of fuel are you using? Also, you may have to cover part of your rads to achieve a good engine operating temperature...
