will 2012 plastics fit on 2009-2010 wr450's
4 replies to this topic
  • aussie_drz400
Posted April 08, 2014 - 03:50 AM
I have a 2010 wr450f,  can anyone tell me if 2012 plastics bolt onto the 2009-2010 models ?
  • funt
Posted April 08, 2014 - 05:32 AM
I think everything but the rad shrouds fits.  The front fender needs 2 holes drilled.  Someone in the big 2012 wr450 thread wired old shrouds to a new tank.  It looked good in the picture.  Maybe it could be rigged?
I popped the necessary parts in an installed a spare set of plastic I had for my 07. The rear fender was identical. 2 of the front fender bolt holes didn't line up, so I filled the existing holes with a hot glue gun and redrilled using the 2012 fender for a template. The rad shrouds were completely different so I simply tied them on with wire.
I think someone said the new side covers fit.  Can't find it.
Edited by funt, April 08, 2014 - 05:53 AM.
  • fixitandy
Posted April 09, 2014 - 02:18 AM
I know the side covers fit, if you get the new style YZ front fender you may not have to modify the the holes, ROOSTA out!
  • aussie_drz400
Posted April 10, 2014 - 12:13 AM
so is it just the fuel tank & seat that need replacing to bolt on the 2012 radiator shrouds ?
  • funt
Posted April 10, 2014 - 03:51 AM
I don't know if it fits the frame but a YZ250F tank is made to work with a carb and used the same shrouds.
