Brand new 2013 yamaha wr450f wont stay running
14 replies to this topic
  • digger0341
Posted April 07, 2014 - 06:17 PM
90 miles on it. Will start and run fine for about 20 sec and then bog down and die. Won't start again unless sets for 5 min. Checked all the obvious spark, vent, gas ect. Wtf
  • bioslayer1
Posted April 07, 2014 - 06:23 PM
When you snap the throttle does it bog down ? If so its a cab problem and you may need to clean the jets
  • bioslayer1
Posted April 07, 2014 - 06:28 PM
If it is fuel injected hookup the wr450f power tuner
  • digger0341
Posted April 07, 2014 - 07:44 PM
Ya its fuel injected. I don't have a tuner.
  • digger0341
Posted April 07, 2014 - 07:45 PM
I'm very familiar with carbs but not injection
  • mikenash
Posted April 07, 2014 - 07:57 PM
From what I hear the bike won't run really well with the stock ecu you need to put the GYTR competition ecu and a pipe and tune it. As the bikes come though very lean.
  • guru
Posted April 07, 2014 - 09:12 PM
So true, but it should run.  I'd pull the tank and check for a pinched / bad fuel line connection.  Others mention the tip over sensor.  Such a new bike, you could call the dealer.  Any crashes, mods, over-heating that you have not mentioned?
I heart my 2013.
  • Silent Echo
Posted April 07, 2014 - 09:29 PM
I have said this before somewhere, but most Japanese bikes get shipped to California, where they purposely jet the bikes super lean to meet California's retarded emissions, sound thing... Usually at higher elevations than Cali they run better, however; your bike should still run.... Geez, that sucks. One reason I'm not a huge fan of fuel injection.
  • vlxjim
Posted April 08, 2014 - 02:19 AM
Check your idle it should be 2000 RPMs. But it does sound like the lean angle sensor.
  • 080
Posted April 08, 2014 - 06:01 AM
+1
Have the dealer you bought it from check this 1st. Manual says 30 seconds then the tip over censor shuts the bike off. Either way it sounds like a fuel issue.
  • digger0341
Posted April 08, 2014 - 06:04 AM
Lol. Drained tank and put new gas in this morning runs fine. Must of had bad gas. Thanks to all
  • vlxjim
Posted April 09, 2014 - 07:51 AM
I don't think thats it. Why would you need to let the bike sit for a few minutes if it was bad gas?
  • smally
Posted April 19, 2014 - 03:45 PM
I've had the same problem with my 2012 wr ... Only concern is you haven't solved the problem . Wouldn't line to see it let you down in remote bush
  • Krannie McKranface
Posted April 19, 2014 - 06:58 PM
I believe that bad gas that has gone into 'phase separation, will run fine till the bike vibrates and mixes the gas.
It will separate back after a while.
  • smally
Posted April 21, 2014 - 12:07 AM
Phase separation is only if your using ethanol fuel correct ?
