After a 2 year break bought me a 2014
15 replies to this topic
  • jeffboyd47m
Posted April 07, 2014 - 06:32 AM
I quit riding 2 years ago to focus on a new business I started in North Dakota. Decided it was time to get back to living and went balls out on a brand new 2014. This bike is incredible and I have bonded very quickly to it. Here is a list of things I have done to the bike.
Ohlins suspension
Ohlins damper
R+D Genius throttle body
Vortex ECU
TM Designs rollers, slider and skid plate
Excell A60 rims
Excell spokes and spline nipples
TCR hubs
Hammer Head brake and shifter
Braking oversized front and Braking rear rotors
Tubliss tires
Sunline levers and clutch perch
X-ring chain and GYTR rear sprocket
Bridgestone front and Dunlop rear tires
GYTR radiator braces
GUTS tall firm seat foam and cover
KX High bend bars
Applied 20mm offset tripple clamps
Spider grips
SignWorks custom graphics
Changed all white plastic to blue
Rekluse core EXP 3.0 clutch
Rekluse Clutch basket and cover
GYTR ignition cover
I have always wanted to go crazy on a bike so I figured why not. Love the end result.
  • jeffboyd47m
Posted April 07, 2014 - 08:11 AM
I also went with DRD exhaust and Bolt axle blocks.
  • seacraft69
Posted April 07, 2014 - 10:28 AM
Guess business is good!
  • Biscuits
Posted April 07, 2014 - 10:40 AM
How are 20mm offset clamps, can you tell the difference ? Do they "weight" the front tire more ?
  • jeffboyd47m
Posted April 07, 2014 - 11:53 AM
The bike turns well with the 20 mm offset. No noticeable wiggle at all.
And yes business is good. Lol
  • crf917rider
Posted April 07, 2014 - 01:55 PM
I have yet to feel the (dreaded wiggle ) on my stock 14, your bike looks great congrats on getting back into moto
  • T-Dub512
Posted April 08, 2014 - 02:33 AM
Bike looks great!
Is that the Stainless or Ti Dr.D pipe? And did you notice any weight savings between it and the stock system?
  • jeffboyd47m
Posted April 08, 2014 - 04:32 AM
Bike looks great!
It is the stainless system. I believe it is lighter then stock, but I really didn't notice the difference on the bike.
  • Brantley
Posted April 08, 2014 - 08:17 AM
Awesome!
Please ride report on Vortex ignition? What can you tell us about it, dead engine starts, low rpm stalling etc.?
I ride tight SE single track, HS, enduros on 10 YZ450 and am curious if it would benefit this type of riding.
Thanks
  • Darvo
Posted April 08, 2014 - 09:12 AM
Did you ride it with the stock throttle body?
What are your thoughts on the R&D one?  Is it as good as they say?
  • YamaLink
Posted April 08, 2014 - 09:22 AM
Balls out is indeed the appropriate phrase. Sounds like you worked your ass off and knew when it was time to get back in the game. Needs vs wants. Good job!
  • THOR450
Posted April 08, 2014 - 12:33 PM
Wow!  Very cool bike!  Tell me about your aluminum scissor lift stand, Who makes it, where to buy and how much?  I have an older team Hawg scissor lift and love it but those aluminum ones are the ticket!!
  • RideBlue3031
Posted April 08, 2014 - 12:51 PM
Looks so badass, congrats on the bike man!
  • jeffboyd47m
Posted April 08, 2014 - 05:58 PM
Awesome!
Thanks
I also ride and race enduro/desert as well as moto. The Vortex was pre tuned as part of the R+D Genius Throttle Body. I owned 2  2010 models and never could reliably pull off an in gear dead engine start. With this bike I am able to start it in gear almost 10 out of 10 tries. At first I struggled with it but found that if I kick it slower, it fires right up every time. The Rekluse pretty much eleminates stalling on it as well.
  • jeffboyd47m
Posted April 08, 2014 - 06:07 PM
I did not ride it with the stock throttle body. I have a friend that has rode both and he claims a very noticeable difference. The bike has an amazingly broad power spread that is very strong. It pulls right off idle right up to the upper RPM range with no flat spots or gaps. Very easy to ride/controlable power. It just seems to put the power to the ground in a deceivingly fast mode. Good stuff!
  • jeffboyd47m
Posted April 08, 2014 - 06:09 PM
I purchased that lift about 5 years ago at Rocky Mountain ATV/MC. I believe it is a MotoSport brand. Been a very good stand.
  • Hot  30 replies
  • 5 replies
  • On January 15, 2017
  • Hot  36 replies
  • 10 replies
