2003 wr450 PLEASE HELP
10 replies to this topic
  • scottw88
Posted April 07, 2014 - 03:26 AM
Hi everyone
Just bought a used wr450 and im wanting it to use on my Ls (btw im from Australia) its got lights blinkers ect but none of it works ive tried new battery and fuses but still nothing could it be the stator if so can someone help me
Thanks
  • YzCas
Posted April 07, 2014 - 03:37 AM
Hi everyone
Thanks
I hate electronics on everything you can buy a meter to read what your stated is putting out. But you probably be wasting your money did you check the ground wire or wires usually if the bike runs stator is okay.It could be voltage regulator :blink:
  • scottw88
Posted April 07, 2014 - 03:41 AM
Its the worst! Feels like im going around in circles! Im a bit of a noob lol from what research ive done the stator is on the left hand side? The bike kicks over fine but when I use the electric start it just makes a sudden noise and thats it, its the only thing from stopping me riding it ahhhhhh
  • YzCas
Posted April 07, 2014 - 04:54 AM
hmmm you said you put a knew battery can you get to the starter to jump the solenoid? Take the starter off clean it,also check the wire connections meaning the ends where there crimped to the wires for the starter and if it has one check the key switch
  • scottw88
Posted April 07, 2014 - 10:33 AM
Ok ill check that out and get back thanks alot!!!
  • Tanis
Posted April 07, 2014 - 03:26 PM
when you say nothing works you mean it wont start?
Testing electrical faults can be a pain in the ass if you don’t work in the right way.
Firstly don’t assume that your "new battery" is good or is charged if you don’t have a meter I would suggest you go and buy one a cheap one from an auto shop will be all you need.
Pick a logical start point. In your case the battery and work forward up the bike checking every connection as you until you get to the lights. Wiggle them and see if you can get the light to turn on. Check all of the wires for damage or crushing between the frame and parts especially under the tank, near the head stem and around the air box.
Check your globes are they all blown? (If so then it’s going to be your regulator or a short to ground)
Check your regulator output with the meter the correct values are in the service Manuel
Check your stator for correct output its not hard the procedure is in the service manuel
Check your flasher works
Good luck!!
  • scottw88
Posted April 07, 2014 - 06:13 PM
Thanks mate after work ive got alot of work to do!
  • JVP
Posted April 07, 2014 - 07:11 PM
Electrical troubles on the WR450 is like a dog chasing its tail.  Welcome to my world......
  • scottw88
Posted April 07, 2014 - 11:21 PM
Any tips jvp?
  • bobpara
Posted April 08, 2014 - 03:57 AM
I bought a Baja kit for my WR and remember it having a rather unique wiring setup. If I remember, the 'core' of the bike ran off of one wire from the stator and all else ran off of the output from another. If ALL (every single one) If every accessory is not working, I'd check the output from the two yellow wires from the stator
  • JVP
Posted April 08, 2014 - 08:55 AM
The system works on a AC (Lights) and DC (Everything else)dual stator. The Stator and Rectifier are usually not the problem. Check your battery first with a tester at the Dealer. I found the Starting Relay do go bad and are a cheap fix. Check for ground faults and start scratching your head. It is a pain....
