mi hedlight 09 wr450. not work
8 replies to this topic
  • PacoPaez
Posted April 06, 2014 - 10:37 AM
Please help no juice at connector bolb is good is tracing wires is goes to under frame what can I do?
Edited by PacoPaez, April 06, 2014 - 03:21 PM.
  • PacoPaez
Posted April 06, 2014 - 06:14 PM
  • flyandride
Posted April 06, 2014 - 07:39 PM
Do you have a wiring diagram?  If not, I can post it here.  The headlight runs off AC and will only work if the bike is running.  There is a black and a green wire to the headlight.  Black is ground and green connects to white coming from the stator.
  • PacoPaez
Posted April 06, 2014 - 10:10 PM
Thanks flyandride in that case I think my problem is coming from the stator broke my side cover and welded it, it is posible stator is toching case?
  • flyandride
Posted April 07, 2014 - 04:49 AM
I would pull the cover and see if the stator is damaged or touching the cover.
  • PacoPaez
Posted April 07, 2014 - 09:45 AM
Yes thats next will do today have to change oil in prep for Baja Ride this weekend
  • jk87
Posted October 10, 2014 - 10:46 PM
Could you please post the wiring diagram flyandride?
  • flyandride
Posted October 12, 2014 - 08:33 PM
  • PacoPaez
Posted January 27, 2015 - 09:17 PM
Wow just foud my post I did find the problem head light wire at the stator cut by the rotor better late than........someone might use this info thanks.
