09 WR450F Headlight Removal
7 replies to this topic
  • UnleashThePwnies
Posted April 05, 2014 - 11:17 PM
I'm looking into removing my WR's headlight and replacing it with a YZ number plate. After a thorough internet search it seems there are possibly some issues with simply disconnecting the headlight, as some people report that their regulator/rectifier break, and either cutting a yellow wire or installing a resistor will stop that from happening. Would I be safe to remove it and not touch anything else, or is the resistor/cut wire needed?
  • GuyGraham
Posted April 06, 2014 - 12:28 AM
I looked into removing mine on my 08, and fired a question to Yamaha UK, via my dealer.
The response back was don't just take the headlight off coz you will have problems, but replace it with a resistor
There was a 'fix' from Yamaha for the YFZ quad which consisted of a ballast resistor, to take the load in place of the bulb to protect the reg rec &/or stator
This apparently fits the WR as well
The electrical power generated by the stator, which can't be 'turned off' has to go somewhere - either turned into light by the bulb, or dissipated as heat by the reg/rec
In the end I left my light on
There are many on here who have just removed the headlight with no ill effects
  • UnleashThePwnies
Posted April 06, 2014 - 01:48 PM
I found this thread, the second post says there is a yellow wire you can cut that will kill the power in the lighting circuit. Would that make the resistor unnecessary?
http://www.thumperta...dlight-removal/
Edited by UnleashThePwnies, April 06, 2014 - 01:48 PM.
  • RockerYZWR
Posted April 06, 2014 - 05:26 PM
For whatever it's worth, I run my bike with the headlight off (switched off, not removed) literally all of the time, and I ride a couple of times a week.  I will have to see if there's excessive heat coming off the regulator/rectifier next time I ride.
  • GuyGraham
Posted April 07, 2014 - 09:49 AM
you can't switch the headlight off on an 07+
They are powered directly from the stator, and only work with the engine running
either you have a pre 07, or you have floated the ground so that all the  power goes to the battery, and the headlight runs from the battery
  • RockerYZWR
Posted April 07, 2014 - 04:26 PM
The only thing is the previous owner did install a Tusk dual sport kit which included an off-low-high switch for the headlight. I don't know if that meant also floating the ground, but I will investigate...as soon as I learn what floating a ground means. Google...activate.
  • UnleashThePwnies
Posted April 08, 2014 - 12:07 PM
I think what i'll do is have a look and unplug the yellow wire coming from the stator to the regulator. I looked at the wiring diagram and it looks like disconnecting it should do the trick and leave all the other electrical bits working.
Has anyone installed a yz plate and kept/relocated the stock speedometer? I don't really want to get rid of it as i like having the odometer function.
  • Mbiker_101
Posted April 09, 2014 - 06:56 AM
I'm looking for a factory wr450 headlight if you guys are removing yours for good, anyone want to sell me theirs? I also have a baja designs high output headlight if any one is interested?
