timing chain-- bumped clockwise
2 replies to this topic
  • ty184e
Posted April 04, 2014 - 07:33 PM
PLEASE HELP!!! so I was adjusting my valves and the TDC mark moved so just thought could bump the TDC mark back turning clockwise. Is TDC still true or do I have to tear more apart? Cams weren't connected was keeping tension with my fingers
Edited by ty184e, April 04, 2014 - 07:44 PM.
  • flyandride
Posted April 04, 2014 - 09:30 PM
TDC is TDC regardless of which way you turn the crank.  WR engines make weird noises if you turn them clockwise.  Don't rotate the engine clockwise but a bump to get it to TDC  won't hurt it.  Sometimes I put a socket on a breaker bar that has no ratchet to get it to TDC.  Then zip tie the breaker bar to a foot peg, frame, whatever.
  • ty184e
Posted April 05, 2014 - 02:58 AM
alright thanks just was being paranoid. I left my ratchet on the crank and turned it to tighten so when putting the chain onto the crank shafts the weight would help prevent it from moving. But thanks for the tip will try that next time to really keep it from budging.
