Gearing for low rpm at 80kph
6 replies to this topic
  • Gink
Posted April 03, 2014 - 06:50 PM
Looking for good front and rear sprocket size to run around 2500rpm on yz450f. Any suggestions
  • Krannie McKranface
Posted April 03, 2014 - 08:29 PM
http://www.thumperta...50-gear-ratios/
http://www.thumperta...-a-yz-and-a-wr/
  • fdme
Posted April 04, 2014 - 08:39 AM
gearingcommander.com
Posted April 04, 2014 - 08:58 AM
In the first place, you posted in the WR forum (it's been moved).
Secondly, what you want ain't going to happen.  If you run a 15/40 (a custom rear sprocket and problems related to the chain slider), 80mph will be just shy of 7000 RPM with a 19" rear.
If you install a WR 4th and 5th, and run the same gearing, you can push that down to 5900.
  • Ukaszs2
Posted April 04, 2014 - 12:17 PM
I have 4 speed transmission from YZ on my WR. My front sprocket is 16 which is max what i could fit there, rear is 48. It is fine ratio for me but i dont ride hard and in 70% on straight field track. Riding on slow sections needs use of a clutch for me, it is easy to stall a motor.
  • DeepPurplishBlue
Posted April 04, 2014 - 12:39 PM
He is not in the USA and asked for 80kph...   kilometers...
80kph is 48mph which is a lot better but I don't see that happening at 2500rpm either
Posted April 04, 2014 - 03:20 PM
Unit slip. My bad.
But then 15/40 or 16/43 would produce 4200 RPM. A pretty low speed, really.
  • Hot  50 replies
  • Hot  36 replies
  • On January 15, 2017
  • 5 replies
