How to mod lever to make clutch pull easier?
9 replies to this topic
  • Blaz1
Posted April 01, 2014 - 09:53 AM
I've read somewhere on here on how to mod either the clutch lever or how the cable is routed to the lever to make clutch pull super easy. Could someone point me in the right direction or shed some light on this? Thanks
  • handreasen
Posted April 01, 2014 - 10:04 AM
squeeze a tennis ball 200 times a day for about 1 month, that should do it!
  • slowmoto
Posted April 01, 2014 - 10:10 AM
My levers have this strap attached which gives more leverage by pulling from the ball end.
  • William1
Posted April 01, 2014 - 10:31 AM
First, ensure all the clutch parts are in proper condition.99% of the time, a rider has a worn out perch/lever/cable or some other shot out part(s).
Every MX bike I have ridden has a one finger pull clutch, if taken care of.
Posted April 01, 2014 - 10:39 AM
Search "easy pull mod".  It's there somewhere.  William is right, for the most part.  Every YZ450 I've ever been on has a maximum two finger clutch pull as it is.
The strap illustrated pulls from both its attachment points, not just the end, so the only thing it accomplishes is shortening the reach.
  • torkd14
Posted April 01, 2014 - 10:58 AM
I only ever use two fingers so I just moved the perch inward to get better leverage by pulling on the end of the lever and my two outer fingers don't get squished
  • slowmoto
Posted April 01, 2014 - 02:17 PM
My strap has the smallest zip tie holding one end so most of the pull is coming from the ball. It is also soaked with paint to make it semi rigid. Pulling closer to the bars puts less stress on your finger.
  • rogo1
Posted April 08, 2014 - 05:02 AM
I have seen people re drill the lever closer to the pivot point to make pull easier, it does work but it will change the sweet spot. you can also buy easy pull levers that are a simple bolt on. I'm not sure the manufacturer, but if you google it you'll find 'em
  • chevyrulz
Posted April 24, 2014 - 12:41 PM
change the clutch springs, and/or the clutch cable or do this:
http://www.thumperta...pull-in-easier/
  • Mbiker_101
Posted April 26, 2014 - 11:26 AM
Here is the link to my mod done back in 2008, I think some of the pics expired. Basically I redrill the clutch lever to change the fulcrum of the cable thus decreasing cable pull.
http://www.thumperta...iker_101#!F1o5U
  • Hot  28 replies
  • Hot  36 replies
  • Hot  30 replies
